Dasan H665 Bridge Mode Configuration, LAN Access, and VLAN Support for Technical Parameters
zwi 24006 6
  • #1 16332382
    zwi
    Dasan H665 is configured in bridge mode.
    Before configuring the mode, the bridge had 192.168.1.x addresses on the LAN side and one more private one, or somehow I will get to it in the current configuration after www?
    Currently, the light is plugged in and the RJ45 goes to the Router port, which has a public IP configured.
    I can not access it from the LAN RJ45 site after the private address.
    Alternatively, does the H665 support the VLAN so that you can get to it and see the technical parameters?
    http://dasannetworks.eu/pl/gpon-ont---h665/161/
  • #2 16333340
    mbo
    Help: 2333
    Rate: 845
    All this supports, but from the operator's side.
  • #3 16333540
    zwi
    Is this module SFP will it be suitable to replace H665?
    Plus Patch SC / APC - SC / UPC.
    I have Mikrotika from SFP.
  • #4 16333657
    mbo
    Help: 2333
    Rate: 845
    It may be appropriate, but it does not have to be.
    There is no compatibility in GPON.
    A separate issue is that the ISP must allow such equipment to operate on the network.
  • #5 16333757
    zwi
    Is the issue of allowing MAC or something else?
    What private IP addresses does this H665 have by default?
    What is the maximum permissible damping for RX TX?
  • #6 16335207
    mbo
    Help: 2333
    Rate: 845
    MAC and type / model of equipment.
  • #7 16338874
    zwi
    H665 normally has DHCP but in bridge mode it may not work anymore so ...
    192.168.55.1
    admin
    vertex25
The discussion revolves around configuring the Dasan H665 in bridge mode, addressing issues related to LAN access and VLAN support. Users express concerns about accessing the device after configuration, noting that the H665 typically has a default private IP of 192.168.55.1 and may not support DHCP in bridge mode. Compatibility with SFP modules and the necessity for ISP approval for equipment operation are also highlighted. The importance of MAC address recognition and equipment type for network access is emphasized.
