Hello, I wanted to connect a single-phase motor directly under the meat grinder without the use of belt pulleys. How to do it? Use a claw coupling? I am asking for advice.
By the way, I'll ask. Which motor must be used to control the speed without an inverter?
What kind of meat grinder you can connect through any flexible clutch. Without the inverter of the asynchronous motor (such as in the picture) it is impossible to regulate without changing the gears.
As a colleague of jerry writes. The inverter is mandatory for smooth regulation of intestinal filling. As for the coupling .... You can connect rigidly provided that you have an inverter and start from the minimum frequency. You can use a clutch, e.g.
And what does the motor have to do to get around without an inverter?
Commutator. It is simply regulated by an ordinary triac dimmer. But no matter what engine, no gearbox. I would use an ordinary drill in such a self-made machine. It has a motor with smooth regulation and transmission.
steve2 I will put a picture tomorrow. The engine gave a different one (it seems that from the old washing machine), because in the previous cable I broke off and I did not want to play. I made a connector with a sleeve bolted, but I did not connect today, tomorrow I will check how it will work n dry.
The machine will not be used for meat, just for squeezing the dough and I do not know if at such high speed the engine will not burn soon.
Helpful post
Clarifying grinder speed, screw alignment, and throat safety
I wrote from work and I exaggerated a bit. On meat grinders such as "Wilk" revolutions are from 150 to 200. And it is not about the speed of grinding but about the alignment of the screw. Additionally think about security. Ordinary razors have a low throat and really a moment of inattention and toes. Look at the ordinary Zelmerk - the narrow and high throat is to prevent fingers from being inserted into it.
Take a look at the OLX ads and see how they have it solved. I also invite you to the "Home-made sausage" forum. There you will find a lot of information.
The discussion revolves around connecting a single-phase motor directly to a meat grinder without using belt pulleys. Users suggest that a flexible or rigid coupling can be employed, but emphasize that speed control without an inverter is challenging. A gearmotor with an output of 300-400 RPM is recommended for effective operation. Alternatives like using a commutator motor regulated by a triac dimmer are also mentioned. Safety concerns regarding the design of meat grinders, particularly the risk of injury from sharp blades, are highlighted. Users share insights on specific meat grinder models and their operational speeds, suggesting that the motor's RPM should align with the grinder's requirements for optimal performance. AI summary based on the discussion. May contain errors.
