Alpha 22 Meat Grinder: Constructing a Claw Coupling for Engine Connection, Reducing Snail Tip Beat
Magister_123 14136 5
  • #1 16900301
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    There is an alpha 22 meat grinder. The turner made some sleeves for it thanks to which he connected it to the engine. It turned out after folding the whole that the tip of the snail (the one that sits in the razor) has a slight beat and the razor dances. To overcome this, he wants to build a claw coupling. I cut the sleeve in half, I put two wheels on it and what next? How to connect the wheels? Screws and something soft between the wheels? Copy finger clutch? Other solution? Screw rotation below 100 per minute.
  • #2 16900314
    Tommy82
    Help: 455
    Rate: 1074
    Father made two plates with pins every 180 degrees between it was a disc with 4 holes of some rubber thick centimeter. The holes in this disc are just so eye-catching and the slack just went off. It was possible to position the machine almost perfectly the second time, because the drill chuck axis and the screw axis were in height. Only this was for alpha 10 where the drill was mounted "permanently" in the handle in the place of side grip and the alpha as it fell alpha 22 has fixtures for permanent fixation. My favorite fun too small was turning up the drill's rotation by a little bit and then a little bit like nobody else was watching and pretending to be stupid then ;) . I was processing half a pig or whole sausage, nobody noticed and I wanted to help it go faster and I didn't understand why they didn't like such help but I still helped :P
    bearq
    Help: 414
    Rate: 1612
    Finger clutch, if you want to be cheaper then such clutches are found in scrap metal and backyards from old water pumps. They were connected by such couplings that transmitted torque through a flexible connector (rubber).
  • #4 16901246
    jalop
    Help: 40
    Rate: 204
    At olx there is such a solution. Welding bends the sleeve that hoho.
  • #5 16902318
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    The bushing is made of a 35mm shaft with a 15mm hole, 55mm long. Welding is unlikely to bend it ;)
  • #6 16902336
    bearq
    Help: 414
    Rate: 1612
    You'll be surprised, you'll be surprised ;)
    Look for such a clutch as in the photo, this is the same clutch I wrote about.
    Throw the turner to fit the coupling halves under the rollers and you will have a problem with your head.
