VW Golf IV 2000 AGR: Hard Shifting 1st Gear - Potential Cracked Part & Replacement Options
Kokuj 19665 14
What is the cracked part in a VW Golf IV gear linkage, can it be replaced, and could it cause hard first-gear engagement?
The cracked part is the gear selector “slip shoe” / bushing, and it can be replaced cheaply, with original VW/Audi parts also available [#16335765] [#16336210] However, the replies say that this part is probably not the main cause of the hard 1st gear; if the gear grinds or is hard to engage while driving, the likely causes are linkage/selector adjustment, gearbox oil, the clutch, or a worn synchronizer [#16336210] [#16336577] A practical check is to disconnect the shift rods and see whether the gears engage cleanly directly at the selector lever, including with the engine off [#16336813] [#16338877] If the clutch is healthy and the problem stays the same, the gearbox itself may need repair or replacement [#16336210] [#16336577]
  • #1 16335685
    Kokuj
    Rate: 30
    Hello!
    I hope it is a good department. I have had IV for a month, I noticed that it is quite hard to run, with great emphasis on the first gear (it cuts halfway and you have to use force to enter, but not always). Twice while driving one, I had a rasp. I opened the mask today and I have questions:
    1. what is the part and where can you get it? - it is cracked (photo 4, 1a, 2)
    2. Is it possible that it is because of her runs that are hard to come by?
    3. what could be the other reasons for a hard falling one? (they enter a hard or warm or cold engine) - please help me
    VW Golf IV 2000 AGR: Hard Shifting 1st Gear - Potential Cracked Part & Replacement Options4a.jpg (3.75 MB)You must be logged in to download this attachment.
    VW Golf IV 2000 AGR: Hard Shifting 1st Gear - Potential Cracked Part & Replacement Options3.jpg (1.56 MB)You must be logged in to download this attachment.
    VW Golf IV 2000 AGR: Hard Shifting 1st Gear - Potential Cracked Part & Replacement Options1a.jpg (2.83 MB)You must be logged in to download this attachment.
    VW Golf IV 2000 AGR: Hard Shifting 1st Gear - Potential Cracked Part & Replacement Options2.jpg (3.12 MB)You must be logged in to download this attachment.
  • #2 16335715
    andrzej20001
    Help: 1578
    Rate: 6669
    The department is ok, but what plane is it from? :) Aha Vw, it should be in ETKA.
  • #3 16335765
    Kokuj
    Rate: 30
    It is called the "foot of slip". I would ask for further questions
  • #4 16336210
    Kantylena
    Help: 18
    Rate: 222
    Yes, this is the VW / Audi shoe slip on the auctions for about PLN 20, even the original VW, but you can not replace it and the new selector is the same, only when it grinds the problem is the worn synchronizer and not the gear shift mechanisms.
    You could still flood the boxes with original oil for VW boxes, but if it's not warm on the warm one, I do not know if it will help.
    Just to regenerate the chest or after the symbol, another used or regenerated with exchange / deposit
    You can also mount a different box, after all, people combine from TDI to gasoline, etc ..
    I had similarly in A3 but in my case there was a massacre on my face, after changing the oil (I think it was mineral there :D ) how he took it away.
    In general, these gears, somehow super, do not come in the sense that there is not much to jump like in the new VAG cars, but ... there is no way to grasp about grinding.
    And the clutch is healthy?
  • Check selector linkage movement before replacing suspected parts
    #5 16336577
    diesel022782
    Help: 13
    Rate: 116
    hello I see that polo lessons have been learned for good day, do not worry about me blocking me, but to heal all this lever is a stake, this ternamid element is a slide, all parts are available, listen to what I tell you from pictures it is not the reason , on the remote control links, check how the selector walks, then check how the leaker gears change, then the oil in the box, I put the clutch in person, greetings
  • #6 16336643
    Kokuj
    Rate: 30
    @ Coupler and clusters were exchanged some 1.5 years ago.
    @ diesel022782 I do not really know how to "play" with these links, etc.
  • #7 16336674
    diesel022782
    Help: 13
    Rate: 116
    Kokuj wrote:
    @ Coupler and clusters were exchanged some 1.5 years ago. The pick is the part, right?
    http://www.fotosik.pl/zdjecie/c571454eda282d75
    but use the same lever to move or float to eliminate it
  • #8 16336716
    Kokuj
    Rate: 30
    pruning sometimes like throwing one, for example
  • Inspect gear selector linkage and lubricate guides under boot
    #9 16336734
    diesel022782
    Help: 13
    Rate: 116
    it's still spruboj, and the guides of the siphon brush some sprey under the bellows, see if it's more
  • #10 16336756
    bula17
    Help: 52
    Rate: 295
    And how do the gears go on the engine off ??
  • #11 16336787
    Kokuj
    Rate: 30
    no difference
  • #12 16336813
    bula17
    Help: 52
    Rate: 295
    Take away the lines and see how physically the gears come directly from the selector level.
  • #13 16336915
    diesel022782
    Help: 13
    Rate: 116
    that's all the time you write, gentlemen, prubees, whether the jack is hit or the selector
  • #14 16338877
    bula17
    Help: 52
    Rate: 295
    Noto, just decide to pull out the links with the jack and put on the gear selector.
  • #15 16339379
    Kokuj
    Rate: 30
    Thanks for the hints, I made small adjustments and it is better. If I have time, I will do as you wrote and let me know
The discussion revolves around a VW Golf IV (2000) experiencing hard shifting into first gear, with the user suspecting a cracked part. Responses suggest that the issue may be related to the "foot of slip" component, which can be sourced from auctions for around PLN 20. Other potential causes include worn synchronizers, gear shift mechanisms, and the need for proper oil in the gearbox. Users recommend checking the selector links and making adjustments to improve shifting. Some suggest that if the problem persists, a gearbox replacement or regeneration might be necessary. The user reports improvements after making minor adjustments based on the advice received.
