Passat b5 - An unusual problem with the automatic transmission
VwDominik 5382 3
  • #1 17013556
    VwDominik
    Hello, I have a Passat B5 1.9 tdi 110km with a 4-speed automatic transmission. My problem is as follows, when I want to start the car, the stick must be set to N instead of P, when it is on P, the car simply does not start. The second thing is gear display, i.e. P = PR = PN = ND = D 3 = D 2 = 2 1 = 2. And the third worst thing is that when he wants to start with D, the car starts with 3 and it goes all the time, sometimes it just feels like it changes gear. When I start with 1 car it starts correctly and when I start with 2 or 3 or D, there is no difference, it is the same as on 3. I read that if the car only runs on 3, it means that the gearbox is in emergency mode, but here you often feel like the car changes gear. I hooked it up after Vag and on the box it read error 01192, which is from what I found out it was a torque converter or TCC valve, but these are probably not the symptoms of what I mentioned earlier? Thank you in advance for any tips on what she owes here. best regards
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    Replace the multifunction switch, the problem raised on elektroda.pl: Passat b5 - An unusual problem with the automatic transmission
  • #3 17014602
    VwDominik
    Will this solve the shifting problem?
  • #4 18086191
    jacenteusz
    Rate: 17
    I have the same problem. Except for the last symptom, which is starting from 3rd gear ... But I'm going to do it. When I find the yew, I will let you know. Unless you've already stated something?
