Peugeot 307 light problem - Automatic crazy light can not be turned off
junior332 20343 5
  • Diagnosing Peugeot 307 automatic and parking light failures
    #1 16336717
    junior332
    Rate: 14
    Hello colleagues. As in the subject I have a problem with automatic light switches. At dusk, automatic dimming beam switches on. In addition, they also turn on during the day regardless of whether the sun is shining or cloudy. It can turn itself off after some time and turn on again in a moment. I tried to turn off the automatic lights with the button in the throttle (auto to peugeot 307 SW 2.0hdi 2003) in the first position of the key. The display shows automatic light on and hear "gong". After repeating the operation, I hear a chime but no display is on the display. When the light switches on with the lights on and the right turn signal lights up, the left light does not. I can not turn on the parking lights, nothing happens and after a while the lights turn on. In the position of the handle, the low beam lights up all the time and does not go out when turning on the turn signal. Halogens and fog functions normally. The problem is as much troublesome as there is no parking and in the day I have to drive all the time on the switched lights because in the 0 position they turn on and off (I live abroad and I do not have to drive 24 hours with the lights turned on). I've been looking for different forums but I have not found a concrete answer anywhere. Can someone advise where lies the probability of the cause, the grip, sensor, bsi or maybe something else and if it can be repaired? I do not want to exchange all electronics around the train. Or maybe it can be disconnected somewhere somewhere, bypass the sensor, etc. Thank you and best regards to your help!
    damdam
    Help: 274
    Rate: 950
    COM2000 or COM2003 damaged. If you exchange for the right one after the VIN, it does not require any additional activities.
    Of course, the subject to be confirmed by an appropriate tester (DIAGBOX)
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • Asking about BSI repair versus replacement and VIN coding
    #3 16336886
    junior332
    Rate: 14
    Thank you for your response. Can you also say if it can be interfered with or better to replace? And what actions do you need to do if you exchange with the wrong vin? I do not have Diagbox, I have to buy and the prices for the diagnosis are space here, so I will wait until I am on holiday in Poland. If it's probably a complex goose buy (maybe it will be used) and take a chance. I have to add that I have a cruise control and a remote control from the radio if it has any meaning. And sometimes the horn does not react, maybe someone wants to fix something there ...
  • #4 16343211
    junior332
    Rate: 14
    Colleagues, can you tell me what is the two-tone cube marked on the picture in the box with fuses under the mask? Someone intervened in the inastalation is connected to the mass relay power supply and one of the connectors from the cube
    • Peugeot 307 light problem - Automatic crazy light can not be turned off 20170313_172426.jpg (263.95 KB) You must be logged in to download this attachment.
  • COM2000 replacement fixes erratic lights but triggers ESP warning
    #5 16385796
    junior332
    Rate: 14
    Some time has passed but I consider the problem to be resolved. I confirm that the reason was the complex switch com2000, I exchanged for another used with citroen c5, the lights are not crazy, I can turn on the parking lights without any problem. Unfortunately, the second switch did not have esp and now I have the control light, I am looking for a solution or it can be turned off. As for the plugin on the attachment, I could not get any information. Thank you for your interest in the topic and best regards!
  • #6 16394541
    junior332
    Rate: 14
    I still have to update. Unfortunately, the combined switch - used as it turned out, did not work 100%. Occasionally, the light automatically turned on for a moment, while the lights were switched on and the turn signal was turned off ... well, this type of it probably has to itself from just breaks down. This time, I only took the switch from the grip, there was a tape and a badge which moved on it. I have gone through everything very gently with the 2,500 paper I put in and it works as it should! Even when it turned out, the car has the function of illuminating after the engine has been turned off with the automatic function, it did not work before. Perhaps the same procedure would help me with the old combined switch, but I do not want to play with it again. In case you had any questions, I'll be glad to help!
