Best Cable Type for 12V 6W LED Bulbs in Soffit - Wiring & Recommendations
rafal.w30 3702 5
  • #1 16337539
    rafal.w30
    Rate: 16
    What cable to power the 12V LED bulbs mounted in the soffit. The power of each is 6W
  • #2 16337559
    polaklbn
    Help: 55
    Rate: 162
    With a cross-section of 2.5mm2, the voltage drop should not exceed 1VDC.
    PS. A light bulb and an LED are two different things.
  • #3 16337565
    rafal.w30
    Rate: 16
    I have MR16 12V 3200K SMD 2835 12V AC / DC bulbs. So a 2.5mm2 cable should be enough?
  • #4 16337862
    polaklbn
    Help: 55
    Rate: 162
    Theoretically yes. Practically, ask the manufacturer whether such a voltage drop will not affect the proper operation of this LED source.
    If you want to be sure everything will be ok, you can use 6mm2 :D !!
  • #5 16338320
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3535
    For what ?
    That's better 2.5 mm2 in the loop.
  • #6 16338880
    polaklbn
    Help: 55
    Rate: 162
    For what ?
    I don't see the possibility of using a loop here.
