Epson XP620 Waste Ink Absorber Removal & Cleaning: Avoid Ink Leak & Reset Pampers Safely
Ash Ketchum 12474 4
  • #1 16338611
    Ash Ketchum
    Help: 39
    Rate: 79
    I have a problem with my Epson some time after the Pampers reset. Well, a lot of ink has leaked from the bottom in the front right corner. How do I remove this waste ink absorber? The vicreset code vendor claimed that you can reset 2-3x on one pampers, and here's something. I will add that there was 45% after reset + 10% trial + factory reset. It could also accumulate a lot, it was a fact. I found such a movie on yt
    Only the XP600 is there, not the 620. And I think the strip at the top of the front has a different shape. 2 screws are. I have a question - can I somehow redo the bottom side to remove this element by unscrewing only one screw from the bottom? Because I twisted and still holds it. Or can I make a hole in the bottom of this sponge container and suck the ink out with a syringe, let it flow out and plug it with a stopper? Besides, I do not want to flood the heads when tilting the printer, although I see the pampers are in a separate chamber, it should not fly anywhere, although it is known that when tilting, etc., then you may need to clean the head as after transport, etc. What to replace the existing dirty sponge with? Or maybe wash it? Just a lot of dirt. I would like to add that I am not going to attach the hoses, etc. to lead the ink outside, only clean and fold it as it was possible to make a hole and release the used ink.
    artin.bruyen
    Help: 13
    Rate: 130
    Yes there are very similar models. Almost identical. You wind it up like the 600 one. You can buy the original pampers for PLN 15, new on the DEA website.
  • #3 16363123
    Ash Ketchum
    Help: 39
    Rate: 79
    Thanks for the answer, it's a pity that it's late because I managed to do it myself according to this instruction. I stuffed the Pampers with lignin but I will buy the original one or sell it to me because I see that it is a warranty service, etc.
  • #4 16363551
    artin.bruyen
    Help: 13
    Rate: 130
    They will sell. Buy ori because your patent is dangerous, you can get dirty and not only.
  • Questioning the original absorber box and lignin material safety
    #5 16363775
    Ash Ketchum
    Help: 39
    Rate: 79
    As you can see, it has a separate pocket for waste ink, so it will overflow as high as the original. I will look there more often and why is lignin worse than the original material? And so when changing the containers, as it poured over me during their initialization and then dismantling, it leaked. But ok I wrote to them. But is the original a whole box, just like a maintanance box in workforces, only without a chip or just filling?
