Yamaha x-max 125 (2013) - How to set the correct time on the display
archei 20895 2
  • #1 16342183
    archei
    Rate: 37
    Dear, how to set the correct time on the display?
  • #3 18681928
    s-e-b-a-s
    To set the clock, press SELECT and RESET together, when the hours are flashing, change them with the RESET button, go to the minutes with the SELECT button, then RESET set the minutes and finally press SELECT again to confirm the setting. In [attach] attachment [/ attach] page from the service center for setting the clock.
    • YP125R_clock_set.pdf (339.72 KB) You must be logged in to download this attachment.
