Vitodens 100W Gas Furnace Controller Options with Tank: Best Choices for Storey House Heating
Kluzniak 11220 10
Which controller should I buy for a Viessmann Vitodens 100-W with a tank and mixed underfloor/radiator heating in a two-storey house, and can I add an outdoor temperature sensor?
The safest choice for this boiler is the original Viessmann controller set with an outdoor temperature sensor; for a cheaper alternative, Euroster 2026 is a viable wired room regulator if you already have a cable, but a simple on/off thermostat is not recommended for a large underfloor-heated installation [#16343360][#16347512][#16343661] Euroster Serwis says the Euroster 2026 connects to the boiler with two wires, works very well with floor heating when set to PI mode, and costs under 150 PLN wired or about 300 PLN wireless [#16348890] Another reply specifically recommends OT regulation plus an outdoor temperature sensor for this kind of setup instead of a basic thermostat [#16343661] If you want the boiler’s full technical capabilities, the replies say that dedicated/original controllers are required [#16347512]
  • Choosing an affordable Vitodens controller and weather sensor
    #1 16343296
    Kluzniak
    I know that the topic has repeated itself a bit, but there was so much information that I have a confusion in my head.
    I'll get to the point. I have a Vitodens 100W gas oven with a container. The stove is in a separate utility room. Storey house, 80% underfloor heating on the ground floor, and radiators with manual thermostats in the rooms on the first floor (I do not know what it is called fachi), and in the bathroom on the first floor a floor. In the living room on the ground floor I have a pulled out cable to connect the controller.
    I do not have any separate control except on the stove which is uncomfortable and not very economical. In general, I would like to invest a little in these drivers, but not to overpay it somehow (I'm not a reptilian and I do not like the difficult handling of extra goodies).
    1. Which driver in this case is best to buy? (friend recommends wireless to me)
    2. Is it possible to have a weather sensor for this furnace? (furnace installer pulled the cable out for me)
    I would ask for some reliable driver recommendation, not some super expensive one, but something that pays off and will work smoothly.
    Thank you in advance
  • #2 16343360
    barteksmrek
    Help: 89
    Rate: 224
    After all, Viessmann has its controllers for its boilers. Weather of course. What boiler is this? One two-function closed open condensate, are we supposed to search the internet?
    READING
    http://www.viessmann-salon.com.pl/pliki/file/TIP%20-%20Vitodens%20100.pdf
    http://www.ogrzewanie.pl/kociol-dwufunkcyjny-vitodens-100-w-6-5-26-0-kw.html
    etc. and so on.
  • #3 16343661
    wawrzeczko_t
    Heating systems specialist
    Help: 199
    Rate: 1033
    I don't recommend the usual thermostat on / off for this amount of flooring. Therefore, a good solution will be reg. OT and outdoor temperature sensor. Cost - approx. 1000 PLN
    https://www.elektroda.pl/rtvforum/topic2936408.html
  • #4 16347162
    Kluzniak
    We have exactly a 26 kW Vitodens 100-W B1HA oven, condensing single function, the chamber probably closed, but now I'm not sure.
    I'm interested in whether it is best to choose a dedicated equipment (or Viessman) or it pays to buy other companies as here on the forum people wrote about some Euroster. For me the most important thing is that it should be easy to use and give something, not break down and work efficiently.
  • #5 16347512
    irus.m
    Help: 122
    Rate: 453
    All technical capabilities of the boiler can be used only with dedicated controllers. This applies to all manufacturers of condensing boilers.
  • #6 16347662
    Kluzniak
    Well, linden, then what should I do? I already wanted to order equipment from the topic "Viessmann Vitodens 100-W - Open Therm (PT52) + TZ sensor + furnace temperature". So what should I call a representative from Viessman? because I will install and set up rather not.
  • #7 16347824
    wawrzeczko_t
    Help: 199
    Rate: 1033
    I'm not sure. However, if they are to be original, you will have the following set (the following amount is the net price):
  • Euroster 2026 PI regulator for floor heating stability
    #8 16348890
    Euroster Serwis
    Help: 20
    Rate: 62
    If you have a cable, I recommend trying the room regulator, e.g. Euroster 2026. This model can be easily connected to this furnace, it is very good at stabilizing the temperature of an installation equipped with floor heating. It is enough to switch the controller into PI mode and connect with two wires to the furnace controller. Price on the Internet less than PLN 150 for the wired or PLN 300 for the wireless version.
  • Assessing Euroster 2026 weather sensing and dual-zone control
    #9 16349554
    Kluzniak
    I think this original set is a bit over the top. many people wrote that they successfully use sensors from other companies (among others, as Euroster Service Engineer wrote). I would like to spend on the controller + weather sensor so about 1000 PLN because I have a very well insulated house and low gas bills, so I do not know if these original drivers would ever return, because I spent little more on the stove.
    Will it be possible to install a weather sensor for this Euroster 2026? How do you recommend it?
    Will euroster 2026 be enough for heating in my house, i.e. radiators + floorboard?
    Is it possible to connect 2 controllers (wired and wireless) to this furnace because in the living room downstairs I have the cable pulled out, but I would like to control the top?
  • #10 16349913
    barteksmrek
    Help: 89
    Rate: 224
    Only the original set and preferably the weather. I have a junkers and he's a superr.
  • #11 16618113
    Kluzniak
    I received so many different answers that I didn't decide on anything. As it is summer and I do not use heating, I am waiting with this problem until October. Probably, because I don't know much about all this, I will probably buy the original set with the weather sensor.
    Anyway thanks for the help.
The discussion revolves around selecting the best controller options for a Vitodens 100W gas furnace in a multi-story house with a combination of underfloor heating and radiators. Users express confusion over the variety of controllers available and the importance of compatibility with the Vitodens 100W model. Recommendations include using dedicated controllers from Viessmann for optimal performance, as generic thermostats may not effectively manage the heating system. The Euroster 2026 is suggested as a cost-effective alternative, particularly for its ability to stabilize temperatures in underfloor heating setups. Users also inquire about the feasibility of integrating weather sensors and the possibility of using both wired and wireless controllers simultaneously. Ultimately, some users lean towards purchasing the original Viessmann set with a weather sensor for reliability.
