Opel Astra PJ - It often shows defects in lights code21, 22, 16
pawel980 39792 5
  • #1 16343758
    pawel980
    Help: 18
    Rate: 225
    Hello, auto opel astra j (IV) after starting the engine, switching on dipped beam often shows errors code 21, code 22, code 16 despite all the lights work as expected, which may be the reason, after pressing the ctrl button the errors disappear after re-ignition show whether do you have to delete something or do I have something to check?
    What could it be?
    Greetings.
    bubu1769
    Help: 1177
    Rate: 2374
    For starters, it's worth checking the embedding of the bulbs and the condition of the connectors from the lamps,
  • #3 16345547
    pawel980
    Help: 18
    Rate: 225
    I dismantled the rear lamps I unhooked the ankles I had drowned in wd40 unfortunately the stop error still appeared as well as the front position lights, despite all the bulbs shines what to do with it? Light controller for replacement?
    szymitsu21
    Help: 343
    Rate: 1300
    check the values of light bulbs. Are they all about the right power, etc.
  • #5 16345821
    pawel980
    Help: 18
    Rate: 225
    No items are w21 / 5w all shines dark glass but it does not matter?
    I press ctrl and the errors disappear and appear only after restarting the car and switching on the lights.
  • #6 16348264
    pawel980
    Help: 18
    Rate: 225
    Hello again, nothing came to mind, I decided to replace the light bulb; putting one new light bulb on the side does not give results, I replaced all positional front and back as well as alloy bulbs.
    At the first attempts to insert one light bulb and to check whether it already "works", unfortunately it did not work, it fired the same in code circle 16, 21, 22 only the exchange in pairs gave the result. Positions ceased to blow up an error when I made a few kilometers probably the bulbs warmed up.
    Everything works as it should.
