Opel Astra H 04r: Horn, Radio, CIM Rollers Malfunction with Dipped Beam Headlamps On
Dawid__W 29859 11
Why do the horn, radio and steering-wheel roller controls in an Opel Astra H sometimes stop working when the dipped beam headlights are on, and how can this be fixed?
The fault is most likely in the CIM module, usually from poor contact between the ribbon cable/tape and the connector, and it can show up when the dashboard backlight is on [#17329213] [#17335607] Several users reported that dimming the instrument/clock backlight to another setting can make the horn and steering-wheel controls work again, at least temporarily [#17328852] [#17454659] A connector clip/clamp was sometimes fitted to improve the contact, but it often only helped the horn and did not cure other CIM problems [#17335607] [#17454677] For a permanent repair, the old CIM can be regenerated/repaired; a used CIM will not work directly without VIN/immobilizer/PIN programming [#17454677] Opel also had service action 10-R-036 for sporadic horn failure, but the clip is no longer available at the dealer and does not solve all CIM faults [#17454677]
  • #1 17328838
    Dawid__W
    For some time I have a problem in my car with no horn signal. Also, the radio and CIM rollers do not work sometimes. I noticed that this condition occurs with the dipped beam headlamps on, while the off-car trumpets normally. Has anyone had a similar problem before? Someone can help solve the problem?
  • #2 17328852
    ak44
    Help: 106
    Rate: 207
    Dim the backlight of the meter and indicators, it should work, yes I do. A tape or connector is to blame. Apparently a factory defect.
  • #3 17329213
    marcov
    Rate: 54
    The most common reason is CIM.
  • #4 17334928
    Dawid__W
    What does it mean? It needs to be replaced, can it be repaired?
  • #5 17335430
    ak44
    Help: 106
    Rate: 207
    They put some clamps on the connectors and the problem goes away. The steering wheel buttons are backlit and this somehow interferes with the buttons. Tinted often helps.
    I will take care of it this autumn, with other repairs. For now, I dimmed and the keys work.
  • #6 17335474
    piotrekwoj1
    Help: 947
    Rate: 3433
    It can be repaired.
  • #7 17335607
    ak44
    Help: 106
    Rate: 207
    I found information on this subject on the internet, I don't remember where. There was a fault described there, also that darkening helps.
    It helped me, I left the topic until autumn. A mechanic's son will come and we'll try to grasp the subject.
    From what I remember, this is a poor contact between the tape and the socket, and it helps to attach the socket clamp.
  • #8 17335871
    marcov
    Rate: 54
    The CIM clip rarely helps. GM saved himself this way but often it didn't help much.
  • #9 17454659
    viru
    Rate: 10
    dimming the clocks helps but you need to choose the right setting (trial and error method) set so that the trumpet works. in my Astra it was almost invisible daylight on lvl.
    what to repair and remove ASO offered me a new CIM module because it rubs the tape, cost PLN 1,500, on the cord you can find around PLN 100 but without guarantee that the problem will disappear
  • #10 17454677
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    viru wrote:
    on the brothel you will find around 100 zlotys
    CIM disassembled from another car will not work in a new one without "cleaning" and programming VIN, immo, PIN, ...
    viru wrote:
    what to repair
    Old CIM can and should be regenerated without any problems.
    Opel Dealership was conducting service action 10-R-036 until 31.12.2012 - regarding CIM and sporadic malfunction of the sound signal.
    At the moment, the "clip" is no longer available at the Dealership.
    It only helped with the horn fault ...
    For other CIM problems, the "clip" does not help.
    Only regeneration.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #11 17454929
    viru
    Rate: 10
    o you see well know for the future each of the 3 workshops in which I was offered to exchange me, but I had to find CIM alone on some other .. szrot etc. because they gave no guarantee. or how my fault won't work
    I will remember thanks
    btw for me at the present moment (tfu tfu) after darkening the clocks the problem stopped
  • #12 18462120
    Bartekas
    I also had a problem with the horn and the operation of the steering wheel buttons. I replaced the CIM module at ASO for a lot of money. Now, when I turn on the turn signals, there is no characteristic "ticking". And the situation from a moment ago, some car got in my way, I pressed the horn automatically and ..... nothing !!!! CIM exchange was in July !!!!!
    I will go to the ASO, but ... How should I explain it ?! A few days ago during the review, despite the lack of "ticking", the horn worked.
The discussion revolves around a malfunction in the Opel Astra H 04r, where the horn, radio, and CIM (Column Integrated Module) rollers fail to operate when the dipped beam headlamps are on. Users suggest that the issue may stem from a factory defect related to the connectors or the CIM itself. Solutions proposed include dimming the dashboard lights, which has temporarily resolved the issue for some users. Others mention that the CIM can be repaired or replaced, with costs varying significantly. There are also references to a service action by Opel regarding CIM malfunctions. Users report mixed results with temporary fixes, and some have experienced recurring issues even after replacing the CIM.
TL;DR: Opel Astra H horn/steering-button failures with dipped beams point to the CIM; service action 10‑R‑036 ended 31.12.2012. "Only regeneration" fixes non‑horn faults. This FAQ helps Astra H owners diagnose and choose workarounds, repairs, or costs. [Elektroda, CameR, post #17454677]
Why it matters: Losing your horn and controls impacts safety and inspection readiness; this guide gets you to a reliable fix fast.
Why do my Astra H horn and steering-wheel buttons fail with dipped beams on?
The backlit steering-wheel buttons load the same path and expose weak CIM contacts. Dimming the backlight often restores horn and key function. The interference hints at a marginal ribbon or connector inside the CIM. Verify by dimming and testing. If it improves, service the CIM connection or regenerate the module. [Elektroda, ak44, post #17335430]
Is there a quick test or workaround I can try?
Yes—use brightness to diagnose.
  1. Switch on dipped beams and the cluster backlight.
  2. Step the brightness down slowly.
  3. After each step, test the horn and steering buttons. Many owners find a very low setting makes the horn work again. [Elektroda, viru, post #17454659]
What is the CIM and how is it involved?
The CIM (Column Integration Module) sits in the steering column and mediates horn, steering-wheel keys, and turn-signal logic. When it degrades, intermittent horn and control failures appear, often triggered by lighting load. Members identify the CIM as the most common root cause in Astra H. [Elektroda, marcov, post #17329213]
Can the CIM be repaired or must it be replaced?
You can repair it. Specialists regenerate CIMs by addressing internal contact and ribbon faults. “Old CIM can and should be regenerated without any problems.” This avoids coding a new unit and restores reliability beyond temporary clips. Choose a shop experienced with Opel CIMs. [Elektroda, CameR, post #17454677]
Will a used CIM work plug-and-play?
No. It needs “cleaning” and coding to your car. “CIM disassembled from another car will not work in a new one without ‘cleaning’ and programming VIN, immo, PIN.” Plan for proper programming during installation to avoid immobilizer and feature issues. [Elektroda, CameR, post #17454677]
What did Opel’s 10‑R‑036 service action actually fix?
Dealers installed a small clip to improve contact for sporadic horn faults. The campaign ended on 31.12.2012, and the clip is no longer available. It helped with horn failures only. For other CIM issues, the prescribed remedy is regeneration. [Elektroda, CameR, post #17454677]
Do connector clamps or clips actually help?
They can help the horn, but results vary. “The CIM clip rarely helps.” It was GM’s attempt to stabilize contacts, yet many cars still needed deeper CIM repair. If your controls fail despite the clip, proceed to regeneration. [Elektroda, marcov, post #17335871]
How much will this cost me?
Expect around PLN 1,500 for a brand‑new CIM at Opel ASO. Scrapyard units run near PLN 100, but come without guarantees and still require cleaning/programming. This cost spread explains why regeneration is popular for reliability and value. [Elektroda, viru, post #17454659]
My horn failed again soon after a dealer CIM replacement. What should I do?
Return to the dealer and document the failure conditions. Ask them to test the horn with dipped beams on and verify indicator acoustics. A fresh CIM should maintain horn and “ticking.” This edge case shows replacement alone may miss underlying issues. [Elektroda, Bartekas, post #18462120]
Why is there no indicator “ticking” sound after CIM work?
A CIM fault or coding issue can mute the turn-signal “tick.” After replacement, verify the sound is present during a road test. If it’s gone, ask the shop to recheck the CIM and related coding. [Elektroda, Bartekas, post #18462120]
Could poor contact in the CIM tape/clock‑spring be the cause?
Yes. Owners report weak contact between the ribbon (tape) and the socket. Adding a clamp improved contact in some cases. Use this only as a stopgap to confirm the fault path. Plan a lasting repair or regeneration afterward. [Elektroda, ak44, post #17335607]
Do radio/CIM rollers misbehave too, and does dimming help?
Yes. Steering‑wheel buttons and rollers can drop out with the horn. Dimming the cluster backlight often brings the keys back temporarily. This points you toward the CIM path rather than the radio head unit. [Elektroda, ak44, post #17328852]
What if dimming and clamps do nothing?
Skip more band‑aids and book CIM regeneration. The clip only helped horn faults, and it is unavailable now. For other CIM issues, the reliable fix is a professional rebuild. [Elektroda, CameR, post #17454677]
Is it okay to rely on dimming for months?
It can keep the horn and keys working, but treat it as temporary. One owner used dimming until scheduling repairs. Prioritize a permanent CIM fix to restore full safety and function. [Elektroda, ak44, post #17335430]
