Opel Astra IV J 1.7 cdti 125km: Orange Key Light On, No Error Code Displayed
Eonisk 82890 7
  • #1 17022162
    Eonisk
    Wiatm. I have a small problem in the guard Astra J 1.7 cdti 125km lights up and a light with a key on orange, but no code is displayed no number. Please, advise me what to do. The car works very well.
    mateov3000
    Help: 50
    Rate: 29
    Probably some mistake in immo, Podepnij as you can possibly also signal a weak battery. If you have 2 sets of keys then you can check
  • #3 17022459
    Eonisk
    But how to check the set of keys? I have two . My car happened 1 month ago, the bumper was repaired outside. Several cars were fired from my battery. My mechanic. Because he said that such a powerful battery. Maybe it's about firing the cables? A hint about how can I check with two keys?
    mateov3000
    Help: 50
    Rate: 29
    Of course I meant a battery in the key if you have the original central in the key. And just wonder what key you mean as a key to a bolt or key as a key to the door because these are 2 different controls and I mean the one with the key to the door which suggests a mistake in the immobilizer caused by a few attempts to start the car without success ( eg damage to the ignition switch's block) or as I wrote earlier, eg a weak battery in the key. It's best to hook up to the computer and see what the error is because it's so many reasons. If you have someone with a cable, it's worth to connect or make a cable that is useful and of course at an affordable price.
    Therefore, I suggest you use the second set of keys and turn on the ignition and the control should disappear. Too fast firing attempt can also cause an error because immo did not manage to read the key. Also, I suggest you check it out because if there are more errors in immo, you can block it and then you will not start the car and only unlock the computer.
    When the battery is discharged also such an error can arise because during the cranking the starter voltage dropped enough that the module immo turned off so that he did not read the key correctly and the error was saved. But after a few attempts to properly fire up, you should disappear but you may also need to delete the computer.
    Also, as you can see the reasons can be many and the exact reason you will see by reading the error codes in immo. diagnostic cable.
  • #5 17025384
    Eonisk
    I connected my friend to a computer. A PO37E error has been displayed
    mateov3000
    Help: 50
    Rate: 29
    The error applies to glow plugs, for example a problem with one of the candles, but it should not light you with the key controls unless it is an engine error indicator instead of an immo.
  • #7 17026588
    Eonisk
    what does engine error mean?
    Added after 59 [seconds]:
    The engine from the injectors for the windshield does not work for me, maybe it also contributes?
  • #8 17027091
    mateov3000
    Help: 50
    Rate: 29
    Maybe from the beginning what your control looks like:
    or maybe:
    Because these are 2 completely different controls responsible for quite different errors.
    The control of 1 photo is a problem related to the immobilizer (errors recorded in it).
    The light from 2 pictures is a problem related to the motor equipment (errors saved in the engine control unit)
    The error you gave after the reading is responsible for heating glow plugs and in such cases the light from the second shot should be on. I suggest you clear the error and see if the error will come back after a few shots of the car if so probably one of the glow plugs may be on the finish or electric connection of glow plugs (solid contacts, etc.) However, if the error does not return, it means that it was a short-term fault eg due to the temperature there was some contact.
    As for the washer motor, it is unlikely to be metered so that you can not see its error by diagnosing the computer and causing it to ignite the above mentioned controls.
    On the forum you will find a lot of information about your error so it's worth reviewing the topics of other forum users.
✨ The discussion revolves around an Opel Astra IV J 1.7 CDTI with an orange key light illuminated, indicating a potential immobilizer issue, yet no error codes were initially displayed. Users suggested checking the key battery and using a second key to see if the warning light disappears. After connecting to a diagnostic computer, a PO37E error related to glow plugs was identified. It was noted that this error typically does not trigger the key light unless there is an engine-related issue. Further investigation into the glow plugs and their connections was recommended, as well as monitoring for any recurring errors after clearing the initial fault.
