Sony Xperia Z Battery Charging Issue: Stops After Few Seconds, Possible 2A S7 Edge Charger Impact
KooGaid 3144 5
  • #1 16346559
    KooGaid
    Rate: 20
    The battery in my office has run out. After plugging in the charger, it charges a few seconds and stops. It happened suddenly, minute by minute. Yesterday I charged it with a 2A charger from the S7 Edge for a while, and nothing happened to it before that. Could the battery be damaged by charging with this charger?
  • #2 16346574
    rosak
    Car dashboards specialist
    Help: 142
    Rate: 559
    No.
    And have you tried to load through this connector from the side?
    Does the data transfer to the computer work?
  • #3 16346838
    KooGaid
    Rate: 20
    I don't have a magnetic cable. The reaction is the same when connected to a computer.
  • #4 16347011
    Adrian4477
    Help: 179
    Rate: 184
    Try on some relatively new cable, sometimes it helps. You probably have the connector already made (unless damaged, broken, etc.).
  • #5 16347014
    rosak
    Help: 142
    Rate: 559
    So the port died. Exchange.
    In my opinion, Sony makes some of the worse USB ports. I changed my wife's tablet after about a year of use. On the phone after less than a year.
  • #6 16349876
    KooGaid
    Rate: 20
    I connected a new cable. Once it started charging from 1% and then it stopped. After reconnecting it started from 77% and it charges. When I run it, Android pops up, optimizing the app. Then the LED flashes that the battery is finished and is not charging it. Second battery inserted, same reaction.
