Sony Xperia Z5 Compact Charging Issue- Phone Charges with Power Bank Cable & Specific Position
lastreal 2871 1
  • Charging works only with a partially inserted cable
    #1 16379802
    lastreal
    Hello, today my Xperia has stopped working with the charger, the phone wants to charge but using the power bank and the charger cable and vice versa, if I connect the charger with the power bank cable, it charges but there must be barely a cable inserted and as soon as I move the phone does not want to charge . I have not seen such miracles, and I do not hide that it is problematic to charge the powerbank to charge the phone, and this is not the fault of the charger because it reacts the same to others only when the cable is not fully inserted.
  • #2 16379850
    nutergsm
    Help: 1034
    Rate: 1666
    USB socket on the phone for replacement.
