Samsung Galaxy S7 Edge Charging Issues: Inconsistent Charging and Moisture Detection Error
damian2017 15003 5
  • Intermittent charging and false moisture detection symptoms
    #1 16292928
    damian2017
    Hello, from the last time I have a problem charging the phone. The wine certainly does not lie on the cable side (I checked several cables). The phone charges normally once, once. Sometimes it pops up, that moisture is detected in the USB input which is IMPOSSIBLE, because the phone is not inserted into the water at all. Recently, when there was still information from moisture, I turned off the phone and my screen popped out with a download and some subtitles in the upper left corner, after a few gofzins I managed to turn it off somehow. Sometimes I do not want to recharge it in any way, I switch it off and if I connect the charger to it, it automatically turns on, but it does not load completely (?????) What is the problem?
  • #2 16293222
    marci4
    Help: 169
    Rate: 177
    The phone is still under warranty, best hand it to the Samsung service. The problem most probably lies on the side of the record.
  • #3 16293404
    damian2017
    Does the warranty still exist if I have a slightly defeated screen?
  • #4 16293421
    venummasa
    Level 19  
    Help: 28
    Rate: 69
    Probably not, probably the connector or somewhere maybe moisture caught (known waterproof but not quite ;) )
  • #5 16295162
    marci4
    Help: 169
    Rate: 177
    Breaking the screen is equivalent to the loss of the warranty.
    I will comfort you here (or not), but maybe it's enough to replace the board with the USB port, the antenna splitter, etc. which is still part of the screen. So it's best to give away somewhere to the site to see how it looks in the middle (whether there is actually no traces of flooding) and possibly substituted a different screen with the tile and saw how it will behave.
  • #6 16641937
    Mati Bierzan
    I just have the same problem, identical concerns, Dowload blue screen, etc. Did you manage to do something about it. ??
