Nissan Qashqai 2.0 Does not start - Nissan Qashqai 2.0 Gasoline does not start a
absolwentppt 8556 2
  • Post-crash no-start with immobilizer warning
    #1 16348591
    absolwentppt
    Hello, I have a problem with a car imported from Germany, after the accident, it is Nissan qashqai 2.0 engine in gasoline 2012, lift after a strong shot, left front, the beam broke off a bit, but everything is in order, and you can not fire, no reaction after turning the key, food pops up orange indicator immobilizer , you can normally close the car, turn on the light, you cannot open the sunroof, I gave it to the Nissan dealership after a week, they could not do it; (only what they generated a new immobilizer code; (do you know an electrician in Greater Poland who could start the car? And in Germany they started the car without any problems) What reason?; (Will someone help?
    • Nissan Qashqai 2.0 Does not start - Nissan Qashqai 2.0 Gasoline does not start a IMG_2047.JPG (5.73 MB) You must be logged in to download this attachment.
    • Nissan Qashqai 2.0 Does not start - Nissan Qashqai 2.0 Gasoline does not start a IMG_2759.PNG (1.56 MB) You must be logged in to download this attachment.
    • Nissan Qashqai 2.0 Does not start - Nissan Qashqai 2.0 Gasoline does not start a IMG_2051.JPG (816.69 KB) You must be logged in to download this attachment.
    • Nissan Qashqai 2.0 Does not start - Nissan Qashqai 2.0 Gasoline does not start a IMG_2046.JPG (1.09 MB) You must be logged in to download this attachment.
    • Nissan Qashqai 2.0 Does not start - Nissan Qashqai 2.0 Gasoline does not start a IMG_2043.JPG (2.35 MB) You must be logged in to download this attachment.
    • Nissan Qashqai 2.0 Does not start - Nissan Qashqai 2.0 Gasoline does not start a IMG_2045.JPG (1.11 MB) You must be logged in to download this attachment.
    • Nissan Qashqai 2.0 Does not start - Nissan Qashqai 2.0 Gasoline does not start a IMG_2044.JPG (1.01 MB) You must be logged in to download this attachment.
  • #2 16348901
    kowal011
    Help: 21
    Rate: 267
    Bump sensor?
  • #3 16352014
    lato8
    Help: 12
    Rate: 148
    what errors on the driver?
    How will you give a plus on the starter it turns?
    Maybe the SRS holds
