Nissan Qashqai 2010, 1.5 dci k9k Engine: Difficulty Starting Warm, Increased Fuel Consumption
mirek2610 16434 12
Why does a Nissan Qashqai 1.5 dCi start worse when warm and consume more fuel after an engine replacement?
Check the live sensor values first, especially coolant temperature, because a temperature sensor can report the wrong value without setting a fault code and cause warm-start problems [#16797677][#16797692] If the temperature readings are correct, the next place to look is the injection system and fuel circuit, not just stored errors [#16801090] Do an injector overflow test and read injector corrections, real vs nominal fuel pressure, and the duty cycles of the fuel pressure/flow regulators [#16800241][#16801090] The forum pointed out that injectors can still let the car run normally once started, yet still cause difficult warm starting and higher fuel consumption [#16800241][#16801090] Replacing the crankshaft position sensor and coolant temperature sensor is a reasonable test, but the advice was to verify these values in diagnostics first and rule out injectors and fuel-pressure components methodically [#16797692][#16800438]
  • #1 16797671
    mirek2610
    Hello, everyone on the forum!
    I am the owner of the Nissan Qashqai year-2010, 1.5 dci k9k engine. In August I had engine failure (broken piston) was replaced with another used engine. The problem is that a cold engine starts better like a warm one. Computer diagnostics did not show any errors. When the engine starts it works perfectly. In addition, fuel consumption increased from 6.2l to 7.5l / 100km.
    Has anyone encountered such a problem, if so help please, because I already lack ideas.
    Thank you in advance.
    Mirek2610.
  • #2 16797677
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    mirek2610 wrote:
    The problem is that a cold engine starts better when warm. Computer diagnostics did not show any errors
    And the data from all sensors (especially temperature) are correct?
  • #3 16797680
    mirek2610
    Komp did not show any errors. Once there was a shaft sensor error (I will replace it) but somehow I am not convinced that this is it.
  • #4 16797692
    jdubowski
    Help: 2511
    Rate: 2804
    I didn't ask about that.
    If the temperature of the block will be 70 ° C and the sensor will report it as 20 ° C, "comp" will not show an error, and you will have a problem with "firing" warm.
  • #5 16797698
    mirek2610
    I didn't check it. I will try to check it again. The weird thing is that it starts quite differently. It happened a few times that he lit the third time in the cold, new glow plugs.
  • #6 16797989
  • #7 16799983
    mirek2610
    If there was something wrong with the injections, would the car behave strangely (power loss, exhaust smoke or other symptoms) while driving?
    Because my nissan if it starts, on the road behaves without complaint.
  • #8 16800241
  • #9 16800395
    mirek2610
    Thank you KotBury for accurate illumination of the problem of injectors. However, I need to tell you more exactly how it happened. Okuzuj original engine suffered a piston failure and I had to replace it with another used. The previous one went without worries to the end. The injectors from the broken engine were replaced they worked until the very end. After the engine start, problems with firing started. Therefore, whether it is the cause of the injectors if they worked flawlessly in the previous engine.
    Kissing Mirek2610
  • #10 16800438
  • #11 16800772
    mirek2610
    The overflow test is carried out as it should be. On Monday I will replace the crankshaft position sensor and the coolant temperature sensor. If this does not help, I know what to do next. The fuel filter was replaced with a new one. After the engine slip I drove about 800km.
  • #12 16801090
  • #13 17490187
    krystian01533
    What a substantive answer to make them only in this forum, thanks to YOU CAT BURY I know that I broke the injection myself :) I mean only valves
The discussion revolves around a 2010 Nissan Qashqai with a 1.5 dci k9k engine experiencing difficulty starting when warm and increased fuel consumption from 6.2 to 7.5 liters per 100 km. The owner replaced the original engine due to a broken piston but now faces issues with warm starts despite no diagnostic errors. Forum members suggest checking sensor readings, particularly the coolant temperature sensor, as incorrect readings could affect starting. Other potential causes discussed include problems with the starter, battery, immobilizer, ignition system, and injectors. The owner plans to replace the crankshaft position sensor and coolant temperature sensor while considering further diagnostics on the fuel injection system.
TL;DR: Warm-start issues after a K9K swap often trace to injector control/pressure faults; injectors see 200–2000 bar, and experts advise to "rule out injectors first." [Elektroda, Anonymous, post #16800241] Why it matters: This FAQ helps Nissan Qashqai 1.5 dCi owners quickly diagnose hard warm starts and rising fuel use after engine work.
Why does my 1.5 dCi start worse warm than cold after an engine swap?
Heat can expose marginal injector control-valve leakage, lowering effective injection during cranking. A misreading temp sensor can also enrich wrongly without a fault code. Start by logging rail pressure versus target, regulator duty, and injector corrections during a warm crank. Perform an injector overflow (return) test to confirm control-valve sealing under heat. “Rule out injectors first.” [Elektroda, Anonymous, post #16800241]
Could injectors be the cause even if they worked fine in the previous engine?
Yes. Different operating conditions, fuel, and debris load can change outcomes. After a swap, low-lubricity (“dry”) fuel or residual particles can score control valves and tips, causing hot-start problems without driveability loss. Do non-invasive checks: overflow test, corrections, filter inspection, and rail pressure data before replacing parts. [Elektroda, Anonymous, post #16800438]
What live data should I record for proper diagnostics, not just code reading?
Log commanded and actual rail pressure, flow or pressure regulator duty, injector corrections, and pre/main/post injection events during a prolonged road test and during the problematic warm start. Clear old codes first to avoid noise. Save a table or graph for review. [Elektroda, Anonymous, post #16801090]
What is a Common Rail diesel injector overflow (return) test?
It measures fuel returned from each injector at idle or cranking. Excess return indicates internal leakage at the control valve or needle assemblies. Balanced, low return suggests healthy sealing. Use matched tubes, equal time, and compare volumes to spot the outlier before pulling parts. [Elektroda, Anonymous, post #16797989]
How do I perform a basic injector overflow test on the K9K?
  1. Connect calibrated return tubes to each injector and route to equal containers.
  2. Run at idle (or crank for a set time) and record volumes.
  3. Compare containers; a high-return cylinder indicates internal leakage requiring further action. [Elektroda, Anonymous, post #16797989]
Should I replace the crankshaft or coolant temperature sensors first?
No. Avoid guessing. Do a structured diagnosis with live warm-crank logging and injector tests. Replace only when data proves a sensor fault. Quote: “Full diagnostics involves… prolonged driving on the street,” with a results table. That approach saves parts and time. [Elektroda, Anonymous, post #16801090]
Can injector faults exist without power loss, smoke, or other driving symptoms?
Yes. Warm-start issues may appear while normal driving feels fine. Small control-valve leaks can hinder starting yet stabilize once rail pressure rises. Increased fuel use can be the only on-road clue. Validate using overflow volumes and injector corrections, not seat-of-pants alone. [Elektroda, Anonymous, post #16800241]
What is the Common Rail system on my Qashqai K9K?
Common Rail stores high-pressure fuel and feeds electronic injectors. The K9K’s injectors and valves endure extreme loads, about 200–2000 bar, billions of cycles over years. Micron-level wear or debris can cause hot-start failures and excess return flow. [Elektroda, Anonymous, post #16800241]
Could the starter, battery, key, or immobiliser cause intermittent starting?
Yes. A weak starter or battery can drop cranking speed and voltage. Dim lights while cranking suggest battery weakness. An immobiliser or key issue can block starting even if mechanical parts are fine. Verify these basics before deeper fuel tests. [Elektroda, Anonymous, post #16797989]
Why did my fuel consumption jump from 6.2 to 7.5 L/100 km after the engine change?
Post-swap, injector leakage, fuelling corrections, or pressure regulation errors can increase delivered fuel. The owner reported this exact rise alongside starting trouble. Treat consumption change as a diagnostic clue and confirm with live data and injector tests. [Elektroda, mirek2610, post #16797671]
Can a coolant temperature sensor cause warm-start trouble without a code?
Yes. If the sensor reports a cold value while the block is hot, the ECU enriches incorrectly and starting suffers. No fault may log. Compare reported coolant temperature to actual engine temperature to confirm drift before replacing. [Elektroda, jdubowski, post #16797692]
What does “dry” fuel mean, and why should I check the filter?
“Dry” low-sulphur fuel has reduced lubricity. It can accelerate wear in the high-pressure pump and injector control valves. Inspect the fuel filter for metallic particles. Finding shavings indicates systemic wear and an urgent need for fuel-system remediation. [Elektroda, Anonymous, post #16800241]
I swapped sensors and filters but still have issues—what next?
Stop random part changes. Do a documented drive-cycle diagnosis with a laptop, capture rail pressure tracking, regulator duty, and injector corrections, then perform an overflow test. Only act on confirmed faults. This prevents wasted cost and time. [Elektroda, Anonymous, post #16801090]
Edge case: It starts immediately when push-started but not with the key—what does that mean?
Suspect the starter. A failing starter can spin too slowly or draw voltage down, preventing a timely pressure rise. Push-starting bypasses that weakness and the engine fires. Test the starter before chasing fuel issues. [Elektroda, Anonymous, post #16797989]
Do glow plugs matter for warm starts on this engine?
Glow plugs help most when cold. New plugs may not fix a warm-start fault caused by injector leakage or incorrect sensor data. Verify glow operation, then prioritize injector tests and temperature validation for warm complaints. [Elektroda, mirek2610, post #16797698]
What single expert takeaway should I follow first?
Perform an injector overflow test and review live injector corrections and rail pressure under warm-crank conditions. “Rule out injectors first.” [Elektroda, Anonymous, post #16800241]
