Nissan Qashqai 2.0dci 2007 - turns, does not start, error P0564
golonkadarek 15297 4
  • #1 16520479
    golonkadarek
    Rate: 22
    Nissan Qashqai 2007 2.0 DCi and as in the topic the car is spinning, it almost catches up but does not start. It lost its power before the failure, then it stopped. Previously, there were problems with starting a warm engine, it burned better on a cold one.
    Error P0564 pops up.
    leonov
    Help: 1039
    Rate: 2248
    P0564 is related to cruise control - broken tape? live parameters checked? fuel pressure, etc.
  • #3 16525090
    golonkadarek
    Rate: 22
    The pump fails to pressurize and the injectors do not open.
  • #4 16526881
    alien8_6
    What did you connect with him? Often, some testers do not see errors in the injection system in these cars and the cruise control error pops up with each engine error
  • #5 16533548
    golonkadarek
    Rate: 22
    He shifted on the timing chain, the turbocharger almost blew apart and a few more little things.
