Focus Mk2 1.8 16v: Setting the Crankshaft Gear for Ford Focus Chain, Cone & No Signs
Marek832506 8880 3
  • #1 16348832
    Marek832506
    Hello, I need help setting the gear on the crankshaft ford focus mk2 1.8 16v chain because the volume is a cone and there are no signs in advance, thank you very much [/ syntax]
  • #2 16348865
    Grubas388
    Level 19  
    Help: 13
    Rate: 69
    To set this timing you will need an Interlock Kit o this Top Dead Center Pulley Lock Motor and a Flywheel Locking Device. Without these blockades, you will not do this engine because with the wrong setting you can make a good mess.
  • #3 16349972
    Marek832506
    Thanks alot ...
    Yes, I know that with the wrong setting it will make a bigos and it's good
    Added after 13 [hours] 57 [minutes]:
    Do you have a diagram for this cylinder head where are the holes for these locks?
  • #4 16352452
    Grubas388
    Level 19  
    Help: 13
    Rate: 69
    When I come back from work I will try to throw in something more url = http: //obrazki.elektroda.pl/1159173300_1489771467.jpg] Focus Mk2 1.8 16v: Setting the Crankshaft Gear for Ford Focus Chain, Cone & No Signs [/url] Focus Mk2 1.8 16v: Setting the Crankshaft Gear for Ford Focus Chain, Cone & No Signs Focus Mk2 1.8 16v: Setting the Crankshaft Gear for Ford Focus Chain, Cone & No Signs Focus Mk2 1.8 16v: Setting the Crankshaft Gear for Ford Focus Chain, Cone & No Signs Focus Mk2 1.8 16v: Setting the Crankshaft Gear for Ford Focus Chain, Cone & No Signs Focus Mk2 1.8 16v: Setting the Crankshaft Gear for Ford Focus Chain, Cone & No Signs
