With what force to tighten the Ford Focus mk1 1.6 16V 100km belt pulley bolt
ustijuf 22686 15
What tightening torque should I use for the crankshaft pulley bolt on a Ford Focus Mk1 1.6 16V?
Tighten the crankshaft pulley bolt to 40 Nm plus 90° and replace the screw with a new one [#16572991][#16573408] The 60 Nm value mentioned in the thread applies to the camshaft sprocket, not the crankshaft pulley [#16572991][#16573408][#16573452]
  • #1 16572243
    ustijuf
    Rate: 96
    I really need the correct tightening torque for the Ford Focus mk1 1.6 16V 100km pulley screw. Please reply.
  • #2 16572259
    sulof1601
    Help: 94
    Rate: 281
    Hello. 60-75Nm
  • #3 16572260
    ustijuf
    Rate: 96
    For sure ? Not enough?
  • #4 16572263
    sulof1601
    Help: 94
    Rate: 281
    The auto data shows a value of 60Nm
    Added after 57 [second]:
    Of course, it's worth using a thread glue.
  • #5 16572269
    ustijuf
    Rate: 96
    What is Auto data
    And how would you do it in this car, how much would you screw it up?
  • #6 16572278
    sulof1601
    Help: 94
    Rate: 281
    Car service program and I have here all the tightening torques and other necessary information about the cars.
  • #7 16572284
    ustijuf
    Rate: 96
    Thank you very much
  • #8 16572991
    moto-kord
    Help: 137
    Rate: 505
    Workshop gives
    Crankshaft pulley
    Replace the screw
    Stage 1 40 (Nm)
    Stage 2 90 (°)
    60 Nm is for the camshaft sprocket.
  • #9 16573174
    sulof1601
    Help: 94
    Rate: 281
    I'm not arguing, but my program clearly writes 60Nm for the crankshaft pulley, I do not know the angle of such a discrepancy.
    Moderated By T5:
    Erroneous advice.
    3.1.11. Do not send messages that do not contribute to the discussion. They are misleading, they are dangerous or they do not solve the user's problem.
  • #10 16573230
    Heinzek
    Help: 554
    Rate: 494
    I have in my autodate like a friend @ Moto-cord
    and 60Nm for the camshaft pulley.
  • #11 16573293
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    This is a spring screw and you can use it only once.
    It turns the corner because it pulls out.
  • #12 16573408
    mario 77
    Help: 66
    Rate: 335
    To be clear and not to mislead others, according to the autodata, it is 40Nm + 90 degrees. So, propose to change or delete this post.
  • #13 16573421
    Help: 1405
    Rate: 6430
    sulof >>>> Exactly so '' 60Nm + NOTHING '' 'please explain or I will get a warning about it.
    Writing stupid is not a forum.
  • #14 16573452
    sulof1601
    Help: 94
    Rate: 281
    I'm sorry, I actually looked at the description and I mistook the next headings and it's like you write 40Nm and 90stop.
    And by the way, I wonder how much after Nm it will be 90 degrees
  • #15 16573494
  • #16 16573698
    ustijuf
    Rate: 96
    Okay, everything is clear.
The discussion centers around the correct tightening torque for the crankshaft pulley bolt on a Ford Focus mk1 1.6 16V. Responses indicate a range of torque values, with some users suggesting 60-75 Nm, while others clarify that the correct specification is 40 Nm followed by an additional 90 degrees of rotation. There is some confusion regarding the torque values for different components, such as the camshaft sprocket, which is noted to be 60 Nm. The importance of using thread glue and the one-time use nature of spring screws is also highlighted.
