Multifun Recalart Settings: PID Turbo Set to 5, Desired Temp 65, Oven at 77 & 100% Power
rosenrot1987 8739 1
  • #1 16351893
    rosenrot1987
    Rate: 27
    Hello, the problem is that five is set to Pid turbo. 65 is desired and the oven goes 77 degrees and 100 percent power. The house lets 66 degrees return 45 degrees
    I set the maximum behind the valve to be 40 degrees but you can see the computer somewhere.
    What is wrong ?
  • #2 17097847
    knedel
    I also have Multifuna but in the Metalbet boiler. I tested software releases for different boilers, in each I had a problem with PID (not enough fuel supply). I am currently testing the SAS version of 17/10/2017. Start by reading this thread, there people wrote the most about this driver https://forum.info-og Heating.pl/topic/22292-sas-solid-ze-sterownikiem-multifun/. Alternatively, if you don't find the answer there, ask, because probably not many people are interested in this driver.
