Equipment for a professional workshop. Which brand to choose Metabo Makita DeWal
Joki123 32886 15
Which brand should I choose for workshop power tools for steel work, and how do Metabo, Makita, and DeWalt compare in reliability and service costs?
For steel workshop use, the thread leans most toward Metabo as the safest overall choice, with several users describing it as solid, comfortable in hand, and trouble-free in daily use [#16353167] [#16726648] For angle grinders specifically, one reply says not to choose Makita, another says Makita is not the best for grinders and prefers Bosch or Metabo, while DeWalt is also mentioned as a good grinder option with vibration-reduction features [#16354102] [#16731368] On service and repairs, Makita is described as the cheapest to repair, while DeWalt repair costs are said to be high, comparable to Hilti [#16352958] One user also warns that a DeWalt screwdriver model had batteries that failed quickly, so battery quality should be checked carefully before buying [#16730920]
  • #1 16352825
    Joki123
    I start steel production. I am currently struggling with the purchase of power tools. It's about angle grinders, mandrel drills, screwdrivers.
    I am asking you, my colleagues, for help in choosing a company from which the equipment would be bought.
    The equipment will be used mainly for work with steel, grinding, cutting drilling, etc.
    As for the topic, I am thinking about buying from 3 companies Metabo Makita and DeWalt. (in the current plant where I work, we use the Hilti brand and it is an unbeatable equipment, but the price is a bit too high for me at this moment)
    I am asking you for help and your experience regarding:
    - reliability
    - warranty service
    - cost and availability of spare parts
    Angle grinders go to the first fire
    http://allegro.pl/makita-szlifierka-katowa-125mm-9565cvr-z-regulacja-i6048084722.html
    http://allegro.pl/metabo-wev-15-125-quick-szlifierka-katowa-regul-i6474329501.html
    http://allegro.pl/dewalt-szlifierka-katowa-dwe4257-d28136-1500w-reg-i6647794840.html
    Best wishes
  • #2 16352958
    qadam12
    Help: 62
    Rate: 254
    The cheapest in possible repairs is Makita, DeWalt repair costs are significant as in Hilti, Metabo I do not know. All you need to do is to see the prices of rotors or breakers.
  • #3 16353167
    arlix
    Help: 17
    Rate: 30
    Hilti, this is not the hilti ....
    For a long time (2 years) I use only metabo, mainly aku 18V. So far, I have not had contact with the service .... A colleague, too, only
    Metabo, in 2 years he fell 1 aku, after 3 days he got a new one.
    The equipment is solid, it's "good" in your hand - I recommend it.
    Arek
  • #4 16353318
    andrzej lukaszewicz
    Help: 626
    Rate: 2120
    And I have some milwaukee equipment and I can recommend it. Hitachi is doing well, but in the event of failure, expensive repairs.
    Everything depends on the service, you need to know and feel when the equipment is overloaded, when the bearing begins to rustle, when the brushes end, etc.
    For myself, I would buy branded, for (sometimes thoughtless) employees - cheaper and good as DWT etc. hardware strong, metal drill bodies.
  • #5 16354102
    beam_beer
    Help: 49
    Rate: 136
    Grinding machines certainly not Makita. Better Bosch.
    Metabo, if produced in Switzerland, then take it, and do not look at the price.
    Added after 14 [minutes]:
    Arek
    That's it with everything.
    Hili, it's no longer Hilti, Mercedes, ladies once did a million kilometers.
    The vacuum cleaner, as you turned on in the morning, turned it off in the evening.
    The battery operated for 15 years.
    And the accountant cried because we produced for good equipment and no one is buying our products anymore.
    And we will produce the remark, let it break, let it have no spare parts, let them buy new ones.
    And so it works, unfortunately. What you do not buy is to break down because the company has to live off something.
  • #6 16354772
    robokop
    Help: 1763
    Rate: 6370
    Boy, are you on Mr. Robert's percentage or what? Bosch was good, yes - twenty years ago. If I had to take it, I would not even think about it - Makita. Even though I have some Bosch, a bit of Celma, a bit of Elprom and Eltos.
  • #7 16355718
    andrzej lukaszewicz
    Help: 626
    Rate: 2120
    I think exactly the opposite when it comes to grinding machines. Generally, I advise you to avoid very well-known brands in our market, because they do popularity analysis and eat on the brand name by making sells like for example VW for many years in cars.
  • #8 16355908
    ALIBABA I
    Help: 223
    Rate: 537
    Hello, I will run away from the subject, I have relied on hilti and makita, and as for Makita I have a saw for this brand oil fuel all in accordance with the manufacturer's standards. taken from the upper half two and a half years, she did not go on earnings, iiii this is not the makita, why AEG ELECTROLUX did not quite sell
  • #9 16726379
    g_egorz
    Rate: 28
    I also have a dilemma and I also take these 3 from the first post. I am going to make the whole set: grinder, drill and hammer drill.
    Has something changed in the topic for half a year? I work in Switzerland so I could buy something ... just choose?
  • #10 16726648
    Joki123
    I decided on Metabo power tools (made in Germany in Lerua I saw Metabo from China much cheaper but I did not risk) and I do not complain. I use angle grinders and mandrel grinders. Very solid equipment. Sometimes he gets a good impression and does not even hare. At the same time it lies well in the paw. I recommend for my part.
  • #11 16726718
    g_egorz
    Rate: 28
    Thanks for the information, I will look in Swiss or German stores. I worked a few years in Norway in heavy industry and was just an old Bosch ... not spared, when you had to always gave advice. After some time, they bought a new Metabo, which started to fall after a year .. and this "diode" next to the cable :P . Now at work we got such "bows" GWS 12-125 CIP, "angular" strong only again "modernization" switch and one hand you do not do, unless you have a forearm like Popey. I always wonder why someone improves something that is good.
    And I write about "angles" .. "simple" Metabo gave advice.
    My dilemma looks like this:
    angle grinders: DWE4257, 9565CVR or WEV 15-125
    hammer drills: D25144K, HR2470T or GBH 2-26
    Drill: DCD730C2 (734), AEG BS18C or METBO BS 18 Quick
  • Battery charger lacks full cell balancing
    #12 16730920
    alfsky
    Rate: 9
    I advise against due to the batteries. They fall like flies.
    I have this model, the first battery fell on the warranty, exchanged in 3 days.
    Another just after the end of the warranty. At a colleague who recommended the screwdriver the same situation. Equipment used mainly for assembly (screwing in m3 / m4), drilling in plastics, reaming steel. I also glanced under the confrymblers when I put my brother's furniture. Because the topic did not give me peace, we went with a friend for exchange of links. It helped. I have an interesting observation about the charger. Probably the manufacturer went a little easier and did not make the full package of the balancer. Only full voltage is output (14.4 between 4 links, and voltage after 1 and 3 link.) No output after 2 links. This can affect the life of the cells.
    The screwdriver itself is flawless, although the diode illuminating the working field is in a bad place and the fur makes a shadow. I saw better solutions
  • #13 16730940
    g_egorz
    Rate: 28
    Thank you very much ... and this screwdriver was supposed to be a surety.
    Somewhere, I read that screwdrivers have a "limit" of charging set to 300 (I do not remember what brand and I do not want to write that it was DeWalt), maybe that was the reason?
    I suppose that with my current applications, the battery will not be charged more often than once a month.
  • #14 16731368
    bearq
    Help: 414
    Rate: 1612
    As for grinding machines, it is only Makita or DeWALT. Makita has very cool GA5030R type small grinders, but DeWALT is more important in something because of the anti-vibration handles, dust rejection or keyless protection.
    Screwdrivers are AEG because of the good and viable battery.
  • #15 16731689
    g_egorz
    Rate: 28
    Or:
    AEG BS18C for this DWE4257 and there is still a hammer drill:
    D25144k (3J) and HR2470T (2.7J) ... I forgive Bosch
    Have you met with the fact that the new Makita 9565 "Made in Romania" grinding machines have a sticker instead of a "convex" name?
  • AEG tools recommended for battery value and durability
    #16 18303767
    Okruch86
    If I were you, I would consider buying power tools from AEG, they have very good batteries, and the price is great, and they do not differ from the quality of workmanship and power of those power tools that cost assets. I have a rotary hammer, an account grinder and a screwdriver at my company and they are unbreakable.
    Moderated By Topolski Mirosław:
    Col. has already bought equipment so far. Please note the dates of recent posts.
The discussion revolves around selecting power tools for steel production, specifically angle grinders, mandrel drills, and screwdrivers. The user is considering Metabo, Makita, and DeWalt, seeking insights on reliability, warranty service, and spare parts availability. Responses indicate that Makita is noted for lower repair costs, while Metabo is praised for solid performance and reliability, particularly in battery-operated tools. DeWalt is recognized for its anti-vibration features in grinders. Some users recommend AEG for its good battery performance and cost-effectiveness. Concerns about the durability of tools made in certain countries, such as Romania, are also mentioned.
