Stuttering screen image - Stuttering image on the second monitor
xBodziu 14499 11
Why does the second monitor stutter and flicker when I use a 144 Hz main monitor and a 60 Hz secondary monitor on a GeForce GTX 960 via DVI?
The stuttering is most likely related to the monitor connection or refresh/configuration, so check that the displays are set as an extended desktop with the correct resolution and refresh rates, and try setting both monitors to the same refresh rate to test [#16353105][#16353254][#16355000] If the problem changes when you swap the DVI sockets, that points to the port or cable path rather than the monitor itself [#16355071] HDMI should also work for the 60 Hz monitor because it carries the same signal, but it is best to test with a borrowed cable before buying anything [#16355117] For DVI, a normal digital DVI-D cable should be fine; cable quality matters more for analog signals [#16356988]
  • #1 16353042
    xBodziu
    Hello, I have two monitors, one main 144hz and the other 60hz and on the second monitor everything is stuttering, for example YouTube lets go, the movie stutters or red dots flicker. I have both monitors connected to DVI. GeForce GTX 960 graphics card. Please help.
  • #2 16353105
    310artur
    Help: 980
    Rate: 670
    Both work at 144Hz? Are you sure you have it configured correctly? How do you change the monitors in places, the problem remains on the additional monitor or follows the monitor?
  • #3 16353110
    xBodziu
    the main one works at 144hz because the second monitor does not support 144hz only 60 :) what configuration do you mean?
  • #4 16353254
    310artur
    Help: 980
    Rate: 670
    One is the main screen, the other is the extended desktop? The card properly tears and sets each resolution and refreshing as needed? It is different with different monitors.
  • #5 16353828
    xBodziu
    so the first is the main screen and the second is the extended desktop. I set the refresh myself
  • #6 16355000
    310artur
    Help: 980
    Rate: 670
    This 144Hz per bank can work as 60Hz try to test them the same refresh. This is just my guess, but you can check it out.
    The other question you have always had is it working and stopped?
  • #7 16355071
    xBodziu
    when I connected it, it was so right now I changed the dvi sockets and I think it's good now. What do you think about the HDMI cable to the 60hz monitor? because I am moving the computer to another place and the dvi cable is too short than the 60hz and the HDMI cable will work without interruption with two monitors?
  • #8 16355117
    310artur
    Help: 980
    Rate: 670
    It should - it's the same signal. Just see for yourself that theory practice one another. Supposedly swapping the sockets should not have an effect, and it does, the same can be with HDMI. If you have the option, before buying, just borrow an HDMI cable or a detachment for a test, a tuner or whatever, if you have an HDMI at home.
  • #9 16355130
    xBodziu
    thanks a lot for your help :)
  • Testing HDMI or DVI cables to isolate monitor stuttering
    #10 16356826
    xBodziu
    how do you think this cable will be good for DVI connection? because my second monitor does not support HDMI: / http://allegro.pl/kabel-dvi-dvi-24-1-dual-link-3m-mm-wroclaw-i6562223023.html
  • #11 16356988
    310artur
    Help: 980
    Rate: 670
    Cable like a cable. Personally, I don't save on cables (because that's what you buy for half your life) and buy in a local shop, trusting the seller.
    It is worth adding - if the monitor is digital, then such a cable will be almost OK for the bank. Cable quality has a greater effect on the analog signal. If it's supposed to be DVI-D that's OK. If DVI-I it can be different.
  • #12 19064928
    Gfshhjelodd
    I have such a problem with connecting the monitor to the laptop and every 2 minutes it cuts off for a while and so what should I do. But if I disconnect the monitor, everything works on the laptop.
The discussion revolves around a user experiencing stuttering issues on a second monitor (60Hz) while using a primary 144Hz monitor, both connected via DVI to a GeForce GTX 960 graphics card. Initial troubleshooting involved confirming the refresh rates and configurations of both monitors. The user later considered switching to an HDMI cable for the 60Hz monitor due to cable length issues, and responses suggested that HDMI should work without interruptions. The quality of the DVI cable was also discussed, emphasizing the importance of using a good quality cable, especially for digital signals.
