iiyama G-Master G2530HSU Black Hawk Monitor: 75 Hz Mode Causes White Screen with Nvidia 1050 TI
szymon22333 5100 4
  • #1 16924838
    szymon22333
    I have a iiyama g-master G2530HSU Black Hawk monitor
    It has the ability to set 75 Hz, when I do it the screen turns all white and the monitor returns after 5 seconds to 60 Hz, or I have to turn it off and on.
    I have installed drivers on the system for it.
    My graphics card is Nvidia 1050 TI.
    Matrix problem?
  • #2 16925889
    DriverMSG
    Help: 3984
    Rate: 4883
    szymon22333 wrote:
    when I do this the screen turns all white and the monitor returns after 5 seconds to 60 Hz
    Do you do it in the options of the graphics card driver or in the options of the monitor?
  • #3 16926203
    szymon22333
    today it came at 75hz for 10 minutes and the screen was white again
    can connect it to Display port instead of hdmi?
  • #4 16926257
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    The whole white screen is:
    - matrix supply shortages or
    - no Voff voltage on the matrix electronics board.
    :?: you have or can display OSD on the matrix at this time.
    ps
    maybe a display issue
    AMD Freesync Technology, 75Hz, 1920x1080 with DisplayPort and HDMI
    so only graphics cards from AMD from Freesync allow this option ?!
  • #5 16926378
    szymon22333
    I have it turned off, in addition, when I move the mouse quickly, the screen does like 3d without glasses, maybe in 75 hz it will be better if I change the cable?
