Peugeot Partner 2010 - Doesn't fire after an accident, shock sensor?
michal_145 14103 6
  • #1 16355506
    michal_145
    The pillow in the car shot out, turns but does not fire.
    Is there a shock sensor in the new partner?
  • #2 16355525
    piotrek22101
    Help: 695
    Rate: 1421
    Check under the hood, around the right (passenger) shock absorber cup, near the windshield.
  • #3 16355560
  • #4 16356257
    michal_145
    Could you tell me if it is possible to start this car and which driver I need to repair?
  • #5 16356886
  • #6 16357143
    michal_145
    I do not have PP2000 but another tester does not show any errors except the fired tensioner and the cushion, I wonder how to start such a car by the time of replacement.
  • #7 16358292
    lato8
    Help: 12
    Rate: 148
    replace / repair pillow driver
    other equipment than the one dedicated to Peugeot / Citroen does not always show the truth
The discussion revolves around a 2010 Peugeot Partner that fails to start after an accident, where the airbag deployed. Users clarify that there is no separate shock sensor; the system relies on the AirBag calculator. To diagnose the issue, it is recommended to use the PP2000 diagnostic tool, as other testers may not provide accurate readings. The user is advised to replace or repair the airbag tensioner and cushion to restore functionality.
