Locating the ABS and ESP Fuses in Engine Compartment of Peugeot Partner 1.6 VTi 2015
jerry67 22035 6
  • #1 17328494
    jerry67
    Hello, the ABS and ESP indicator lights are on - are these fuses and which are in the engine compartment? maybe someone has a schematic?
    is this another problem
    Regards
    • Locating the ABS and ESP Fuses in Engine Compartment of Peugeot Partner 1.6 VTi 2015 IMG_20180714_132533.jpg (3.66 MB) You must be logged in to download this attachment.
  • #2 17328568
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    You look good.
    Pull out the BSM and you will have the rest of the fuses underneath.
    Fuses of 50 - 80A
  • #3 17328651
    jerry67
    and which is BSM? how to draw it
    Added after 21 [minutes]:
    ok. i got it but all the whole. are those plugged from the forehead?
    Added after 29 [minutes]:
    The computer shows ABS ESP ASR fault
  • #4 17328804
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    And the picture you added? Packets of sugar?
    You have BSM saved in the bottom left corner.
    I wrote a post earlier that fuses are also underneath. You can't see them from the top.
    The on-board computer gives this error.
    Under the diagnostic computer you will find out what the problem is.
    Maybe the sensor is damaged and the power supply is correct?
  • #5 17328829
    jerry67
    Power? it seems so ... but I'm not a specialist.
    The sensor is half poor, not a pump
    Added after 4 [minutes]:
    And this happened after I drove through quite deep water
  • #6 17330206
    Luc3k
    Rate: 14
    If you are already experimenting with repair without any computer diagnostics - check the wiring of the rear wheel speed sensors (wires on the car - not those thick from the sensors but twisted in a pipe).
  • #7 17330227
    jerry67
    Ok, I will
The discussion revolves around locating the ABS and ESP fuses in the engine compartment of a 2015 Peugeot Partner 1.6 VTi, prompted by the illumination of the ABS and ESP indicator lights. Users suggest checking the BSM (Battery Supply Module) located in the bottom left corner of the engine compartment, where fuses ranging from 50 to 80A can be found. The original poster expresses concern about potential sensor damage after driving through deep water, and further advice includes inspecting the wiring of the rear wheel speed sensors. It is recommended to perform computer diagnostics to accurately identify the issue.
