Ping jumps every 30-60sec after turning on "League of Legends"
Tekuuu 5439 6
  • #1 16355992
    Tekuuu
    Hello, as in the topic ... Ping (in the console) is normal, but by the time I turn on, or rather enter the game. After some time the ping starts jumping from 35 to 150-250. And so every 30-60 seconds. After turning off the game, jumps stop after some time. In short, these ping spikes are in-game only. I also noticed that this happens after the computer format (new disk), before the format I had no such problems and the ping was normal during the game (I don't know if this information is important). I connect to the router via cable. Thanks in advance for any attempts to help me.
    Router: Funbox
    Speedtest: http://www.speedtest.pl/test/145613012
    EDIT: Ping spikes now even occur when I'm not using anything or playing: v
    jimasek
    The system or some application is not accidentally downloading any updates in the background? Have you checked what is happening in the system's Task Manager, is something overloading the system itself?
  • #3 16359198
    Tekuuu
    I noticed that the problem may be ... Teamspeak; -; When ping spikes appear in CMD, you can see in the processes that Teamspeak uses more "Network", "Disk" and "Memory"
  • #4 16359204
    jimasek
    Then follow this lead. The question is whether the application is updating or communicating with its server.
  • #5 16359218
    Tekuuu
    The problem occurs only on one Ts server, on which I was spending the most time ... So just the server's fault?
  • #6 16359226
    jimasek
    I don't know that, because I don't know much about online games (I'm not interested in that). The application itself is the latest version? Does it not download updates at this time or does it not refresh its content?
  • #7 16359315
    KOCUREK1970
    Disable in process manager, and test without it.
The user experiences ping spikes in "League of Legends," fluctuating between 35 and 250 ms every 30-60 seconds after launching the game. This issue arose following a computer format and does not occur when the game is off. The user connects via a Funbox router and has noted that ping spikes also happen when not actively using the computer. Responses suggest checking for background applications, particularly Teamspeak, which may be consuming network resources. Disabling Teamspeak was recommended as a potential solution to the problem.
Summary generated by the language model.
