Experiencing Sudden FPS Decrease in League of Legends - From 200 to 60
KaMiLQ11 12384 7
  • #1 16468440
    KaMiLQ11
    Hello, I have a sudden decrease in fps, for example, I will say that in the League of Legends on Sunday I had 200 fps on high and on Monday I have max 60 you know what the problem is?
  • #2 16468453
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    From the information given, I can recommend a visit to the fairies on Thursday.
  • #3 16468479
    KaMiLQ11
    What information you need is a gtx 1060 card. I5 6500 processor and that's it if you write something else
  • #4 16468491
    Kasek21
    Help: 4981
    Rate: 3547
    Vertical sync is not forced?
    What temperatures?
    Install and run HWiNFO64 (sensors only), then start the game, play for 10-20min. and upload a screen from the program.
  • #5 16468553
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    Full equipment stocking is best.
    As for the defect, I recommend a test lasting several dozen minutes with the OCCT program and throwing screnches after the test.
  • #6 16468569
    KaMiLQ11
    I have the program cpuidHw monitor and when I played. Temperatures never exceeded 55 degrees.
    What is it about vertical synchronization what is it?
  • #7 16468972
    mikomaaz
    Help: 18
    Rate: 33
    Vertical synchronization is a graphic simplification. :) It can be turned on or off in the game options.
    Did you do something on the computer at the beginning that would result in downloading the virus? What does the disk look like? How much free disk space do you have?
    Upload screenshots from HDTune or Crystal Disk Info. Scan positively with your anti-virus, Windows Deffender, MalwareBytes and AdwCleaner. If your system is Windows 10 and you have an additional anti-virus then you can remove it so that only Win Deffender is left.
  • #8 16469424
    Kasek21
    Help: 4981
    Rate: 3547
    Post screen from Process Explorer.
A user reported a sudden drop in FPS while playing League of Legends, going from 200 to 60. Responses suggested several potential causes and solutions, including checking hardware components (GTX 1060 graphics card, i5 6500 processor), ensuring vertical synchronization settings are correct, monitoring temperatures (not exceeding 55 degrees), and scanning for viruses or malware. Recommendations included using tools like HWiNFO64, OCCT, HDTune, and Crystal Disk Info to diagnose issues, as well as ensuring sufficient disk space and checking for background programs that may affect performance.
