2.2CDI sprinter swap to 2.9TD - Replace the injection pump in 2.9TD with a mecha
entyowenty 6975 5
  • #1 16356033
    entyowenty
    Hello, I am trying to replace the engine in the 2.2 CDI sprinter. This engine, probably the worst in the history of MB, has already died several times, so I decided to put a 2.9 TD engine there. So far I don't have a donor or the 2.9TD engine itself and I'm figuring out how to bite it. Occasional ads disappear faster than they appear, it is much easier to buy a complete engine than to hunt a whole car in the vicinity of Warsaw and swing it after it is unloaded. I have two injection pumps from 2.9 engine without turbo and this idea:
    I wonder if it would be possible replacement of the electronically controlled injection pump in the 2.9TD engine with a mechanically controlled one . This would solve a lot of problems with rearranging the beam, immobilizer, computer, much easier.
    Apart from other issues of this idea, I would like to find out if any of you have tried such an art, such a pump can somehow be set up for work with a turbine. The loss of a few horsepower and increased fuel consumption does not scare me, the engine is supposed to have torque and be trouble-free in use.
    Maybe someone has done something like that in CDI remakes, old Mercedes cars, or off-road vehicles, where computers are unwelcome?
    The topic of replacing the 2.2 CDI engine with 2.9TD does not exist on the web, I did not find anything, but I do not believe that no one has tried anything like this. I am asking for tips, work starts in the spring.
    Thank you in advance!!!
  • #2 16693069
    KubaWWL
    hello, was the swap successful? how did you solve the installation topic. I am at the stage of throwing the 2.9 TD engine into the VW LT, which was originally a 2.8 engine
  • #3 16694737
    Jackall
    Help: 77
    Rate: 393
    I know a mechanic who specializes in MB to inline electronic pump spacers. They come to him from all over Poland. It takes over the car in one day. How can I give you a bearing on
  • #4 16751071
    Damianosik
    Cuba, how's the swap?
    I am almost done, there are small tachometer and liquid temp.
    Check speedometer etc.
  • #5 17047843
    encyklopedysta
    Rate: 12
    Hello, group.
    I have a question for the forerunner if he is still here and the project is finished. Possibly to others who know the topic. Namely, I also lost 2.2 cdi and put 3.0 with a mechanical pump, but I have a problem with the engine temperature and tachometer. Sprinter 2003. I had the sensor in the thermostat housing and for a moment, even with the jumper where the temperature indicator should jump to max, nothing happens, the same with the engine speed - I take the shaft rotation sensor from 2.2 simulates the movement of the shaft and also dead. I hope that at least the oil sensor will work after the pan has been reworked and installed. Alternatively, could I remove the computer from the cdik and somehow control the clocks themselves to make it work? Thank you in advance for your suggestions. greetings
  • #6 17207290
    look1990
    It's best to get the counter and lines / e beam from the same version of the engine and try to make 2 meters 1. A colleague in the audi 80, for example, added a tachometer in place of the watch and it works. There are several meters in this version on the popular auction site, just enter the phrase 3.0 d or 3.0 td mercedes and that's it.
