Renault Megane II 1.9 dci 120k - Changing the dual mass flywheel to a rigid one
grzes7113 5010 5
  • #1 16357693
    grzes7113
    Rate: 62
    Hello, does anyone know whether a stiff wheel, for example from Renault Trafic, will approach the Renault Megane II 1.9 dci 120KM? I read that the Lagoon is set up and fits, but the lagoon has a different diameter of the disc and wheel.
  • #2 16358123
    lato8
    Help: 12
    Rate: 148
    In the 100-102KM version I saw a stiff wheel, Space Star 1.9 DCI 102 KM and the Carisma also has a stiff wheel with this engine.
    A 5-speed diesel should be on a stiff wheel and you can buy a used one.
    I just don't know if the thickness of the set of such a clutch will correspond to the thickness of the original, and thus whether there will be problems with disengagement.
  • #3 16359590
    grzes7113
    Rate: 62
    Well, only that the megane or the scenic 120 km had a dual mass wheel, now the question is what the rigid wheel will fit
  • #4 16360718
    krzysiek7700
    Rate: 8
    I have already seen a dual mass wheel welded together several times and then everything fits only, I propose to put discs with springs because it is a waste of the gearbox
  • #5 16364504
    grzes7113
    Rate: 62
    I mean exactly the model from which the rigid wheel fits, welding is not a problem worse with balancing
  • #6 16364961
    kakibara
    Help: 202
    Rate: 1284
    Megane 2 from 2002 engine code f9q 800,
    valeo no.835152, valeo no.845048 with hydraulic element. - for reconstruction.
    valeo without Valeo 828109 flywheel.
    that was it?
    fits scenic 2 and 3, megane 2 and 3, grand scenic,
