Fiber Optic Connection Costs: Connecting Home 300m from Road - Pricing & Installation
mateuszb6 25026 9
How much does it cost to connect a house to fiber optic internet when the line is about 300 m away from the road?
The price cannot be determined from distance alone; it can range from PLN 1 with a 24-month contract to around PLN 50,000, and even a 300 m extension to one house may not be built by Orange [#16359099][#16359157] The cost depends on what kind of fiber it is, who owns it, and how far the nearest switchboard or connection point is, because fiber cannot simply be tapped in anywhere like water or gas [#16359106][#16359121] If the line belongs to Orange, the forum advice is to ask Orange directly and check service availability for your address [#16359130][#16359132]
  • #1 16359091
    mateuszb6
    I have a question how much it will cost me to connect the optical fiber to the house, the fiber runs near the road 300m from the house I am interested in the rounded price of such a connection
  • #2 16359099
    m.jastrzebski
    Help: 679
    Rate: 865
    Depending on what kind of fiber optic cable and who it belongs to, it will cost you from PLN 1 (for 24 months) to PLN 50,000
  • #3 16359106
    jimasek
    Help: 3783
    Rate: 2681
    The question is what is an optical fiber because there are several types and many different operators. So the question must be addressed to the owner / operator of the cable or infrastructure.
  • #4 16359118
    mateuszb6
    the company that set the optical fiber from what I know is orange and what kind of fiber is that I do not know
  • #5 16359121
    sanfran
    Help: 963
    Rate: 3004
    Optical fiber can even run near the house and nothing will come of it. The question is how it is far to the closest switchboard, switchboard, etc where it will be a fiber optic switch.
    It is not a water supply or a gas pipeline, where you can plug in a pipe anywhere.
    Secondly, this optical fiber can be used by the operator for a purpose other than the internet.
  • #6 16359130
    jimasek
    Help: 3783
    Rate: 2681
    So, direct the question to Orange. We will not tell you anything specific about this topic on the forum.
  • #7 16359132
    m.jastrzebski
    Help: 679
    Rate: 865
    mateuszb6 wrote:
    and what kind of fiber is this I do not know
    Well, we do not know how much it can cost. We know, however, that depending on what is the optical fiber the nearest point in which one can connect can be kilometers further.
    And if it is Orange then you go to the customer service office and ask for an internet offer at your address.
  • #8 16359146
    mateuszb6
    the nearest point connects to just 300 m because just in my house a well that indicates the place to connect
  • #9 16359157
    m.jastrzebski
    Help: 679
    Rate: 865
    Not 300m just "probably" 300m, because as you write, you do not know what kind of well it is and what is the optical fiber.
    And even Orange will not build a 300m connection for one house. Even if there were 20 houses at the end, they will not build themselves. These are costs of several tens of thousands of PLN depending on the area. Sorry, we have a country like that. Maps, projects, permits, agreements.
    Go and ask. On their website there is also a search engine for service availability by address. What I do not know.
  • #10 16359162
    jimasek
    Help: 3783
    Rate: 2681
    I close the topic because further discussion does not make sense. @ mateuszb6 please contact the operator.
The discussion revolves around the costs and logistics of connecting a home to an optical fiber network located 300 meters from the nearest road. Responses indicate that costs can vary significantly, ranging from PLN 1 to PLN 50,000, depending on the type of fiber optic cable and the service provider. The importance of identifying the specific type of fiber and the operator is emphasized, as different operators may have different infrastructure and policies. The operator mentioned is Orange, and it is suggested that the user contact them directly for a precise quote and service availability. Concerns are raised about the feasibility of connecting a single house to the fiber network, as it may not be economically viable for the operator to extend the connection for just one residence.
