Renault Kangoo: Adding 1.5 dci Injectors - DDCR 8200303623/8200129109, Addressing Replacement Codes
SanchosX 10347 5
  • #1 16361912
    SanchosX
    Rate: 75
    Hell, I can't add injections to my computer.
    It does not accept codes from injectors that are in the car
    The computer was replaced
    Now all injections are described as 3042042042021010, I know that this is a replacement code
    Maybe someone has codes that would come in
    The driver is
    DDCR
    8200303623
    8200129109
    It seems to me that the injectors in the car are of a different class and that is why the computer does not accept them.
    Kisses
  • #2 16361943
    szymitsu21
    Help: 343
    Rate: 1297
    it is not enough that it accepts any codes. It is not without reason that each injection has a different one to add any other.
    What was the reason for the ECU being replaced?
    On the same?
  • #3 16361977
    SanchosX
    Rate: 75
    old computer has been stolen
    vintage similar
    A set of codes would help me get the car screwed up.
    If it's ok, the injections will be replaced or new codes will be established
    genek1000
    Help: 289
    Rate: 1056
    Rather, codes are not collected because what for :D
    I have left over from the last repair. I don't know if to "your version". Try it, maybe they will come over.
    With codes for 1.5 dci there are two types of injectors "strong" for 80 and 100 KM and "weaker" for 60 KM. You will not "train" the "weaker" injectors to the "stronger" program and vice versa.
  • #5 16364969
    kakibara
    Help: 202
    Rate: 1283
    I changed the injectors 3 times, after a few minutes of idling and the route the light disappeared by itself.
  • #6 16366621
    SanchosX
    Rate: 75
    Thanks to my colleague, I found a set of codes on the internet and it went
    The weirdest thing is that I punched in the codes for 20 injections and it didn't work
    The next day I got the codes from the net and it went right away, then I added the codes from the injections from this car and 3 codes accepted one no (probably someone replaced it with another, as my colleague GENEK writes)
    The strangest thing is that it did not accept the original codes before, and after adding the codes from the net, it already accepted the codes from the injectors from this car.
    Of course, as soon as the codes were added, the car left the service mode and started responding to gas.
    Cheers and thanks for the codes
