Renault Kangoo 2010 1.5 dCI Injector Adaptation Procedure: Resolve DF859 & DF053 Errors
sadek1979 26019 2
  • #1 16704379
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1419
    As in the subject, I need a procedure to adapt the injectors to Kangoo 2010 1.5 dci. I am forewarning your suggestions about adding injectors. These are two different procedures. I do not have access to dialogys and I do not know how to perform the above-mentioned adjustment. Clip shows error df859 - injector adaptation cycle not performed and df053 - rail pressure adjustment function Both may be the result of the first error. Best regards .
    lukash3
    Help: 24
    Rate: 133
    As below:
  • #3 16705409
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1419
    Thank you so much that was the point.
