Ford Focus MK1 2001 - Central locking (universal) only opens.
sewbia 9672 5
  • #1 16362146
    sewbia
    Rate: 13
    I bought and installed a universal controller. Wires connected according to diagram sent by the seller. Picture below. The controller only opens the door and the closing button on the remote control. Pressing the others has no effect other than blinking the direction indicators. Anyone smarter than me knows what could be the reason?
  • #2 16362458
    bodzio012
    Help: 161
    Rate: 779
    Make sure yellow, yellow-black and black are well connected to each other to ground
  • #3 16362814
    sewbia
    Rate: 13
    I am 100% sure of this one. The mass was screwed to the factory bolt on the post. After unscrewing the controller does not work at all. I will add that after opening (closing button) the driver LED flashes indicating that the car is closed even though it is open. When the opening button is clicked on the remote control, the indicators turn off, the diode goes out but there is still no reaction.
  • #5 16363259
    gemiel
    Help: 79
    Rate: 307
    Check the operation of the lock by manually entering the mass once in black / green and once in black / orange.
    If the lock works correctly, you can check the operation of the controller by connecting, for example, a bulb tester to a permanent plus and checking if there is mass on white and white / black when using the remote control.
  • #6 16365127
    sewbia
    Rate: 13
    And the problem is solved. The problem was the comfort module (of course the one with the pink) sticker. Replacing the module for PLN 14 solved the problem.
