Laguna III, 2.0 dci, 2013: Identifying Fuse for Rear Door Lighting
tomaszi44 5478 5
  • #1 16423663
    tomaszi44
    The rear door lighting went out yesterday - the front door lighting (driver and passenger) still works.
    The question is which safety is responsible for the lighting in the rear doors?
    Maybe someone has a description of the fuse box in Laguna III, 2.0 dci from 2013?
  • #2 16423683
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    What have you already done / excluded? Have you checked the fuse panel or are you just asking which fuse is it or is it at all?
  • #3 16424363
    tomaszi44
    Since the lighting was on both sides at the same time, I assume it's a fuse - I have no idea which one.
    I hope that someone has already trained this at home or has a list of fuses in this car.
  • #4 16424387
    marqqv
    Level 32  
    Help: 162
    Rate: 609
    If you know where the fuses are, I'm surprised you prefer to wait for the answer where the fuse is instead of checking it yourself. So it comes out that maybe better for the workshop.
  • #5 16424548
    wojciech80
    Level 19  
    Help: 26
    Rate: 34
    And buddy, you checked the light bulb ?.
  • #6 16490184
    lechos
    Help: 27
    Rate: 96
    The question ...... were these lights in the back door lit up before. I don't know how after the lifts but before it in the back door there were only reflections ;)
