Choosing a screwdriver up to PLN 300.What do you recommend ??
Uczeń Mechanik 4923 8
  • #1 16224356
    Uczeń Mechanik
    I would like to buy a screwdriver. It seems to be a simple thing but ... I don't know what parameters to pay attention to, what tool brands should I be interested in? I would like the new purchase to be used a bit and not fall apart after a fairly short time ... I think that the first screwdriver up to PLN 300 will be available from the middle shelf? What do you think about it? What are your suggestions?
  • #2 16224418
    trance123
    Help: 27
    Rate: 134
    Would it be useful to know what you want to do with it, do you need a stroke and two batteries?
  • #3 16224449
    Uczeń Mechanik
    Stroke not necessarily. At present, 1 battery is enough.
    Added after 6 [minutes]:
    I would like to add that it will not be used professionally, rather it will be used for home needs.
  • #4 16235862
    Pomocyyyy
    I have had a skil 1003 18v screwdriver for several years. Personally, I am happy for housework, 2 batteries. The only thing I do not like is the original set of bits, the defeat works right away. The price is about PLN 300 new.
  • #5 16235877
    Uczeń Mechanik
    I care about battery LI
  • #6 16235892
    Pomocyyyy
    Skil has Ni-Cd 18v 1.2 Ah
  • #9 16236333
    Pomocyyyy
    I think that at home it should be enough, for harder work it is rather not available, 29 Nm is unlikely to cope with coarse work. If you just need to screw something in or drill a hole from time to time, it should be enough. best regards
The discussion revolves around selecting a screwdriver within a budget of PLN 300, focusing on home use rather than professional applications. Key considerations include the type of battery, with a preference for lithium-ion (Li) over nickel-cadmium (Ni-Cd). Recommendations include the Skil 1003 18V screwdriver, which features two batteries but has a subpar bit set. Another suggestion is the Bosch GSR 1080-2-LI, noted for its 28Nm torque and 1.5Ah battery, suitable for light to moderate tasks. A Nutool 18V model was also mentioned, though its capability for heavier work was questioned.
