Fiat Ducato 2.8 jtd 2001 - OBD1 3-Pin Socket Diagram for ECU Communication Issue
strazak2000 18159 15
How do I wire the 3-pin Fiat diagnostic socket to communicate with the ECU when one wire seems broken and there is no ECU communication?
You only need power, ground, and the K-line for this ECU, so the missing L-line is not the reason for the communication problem [#16363816][#16363864][#16363885] Check that the middle pin has ground, because that pin should be mass/ground in the socket [#16363436] If you want to adapt it to OBD2, wire the correct power, ground, and K-line positions and verify continuity from the plug to the ECU rather than relying on the socket alone [#16363379][#16363511][#16363885] The immobilizer being removed should not affect ECU communication [#16363511] Autocom/Delphi and possibly Multiecuscan should work once the wiring is correct [#16363950][#16363983]
  • #1 16363268
    strazak2000
    Rate: 8
    Hello, I need a socket diagram for a 3-pin Fiat because one cable does not go to the computer and it is probably damaged - no communication with the ECU. Someone help?
    krystek86
    Rate: 30
    Fiat Ducato 2.8 jtd 2001 - OBD1 3-Pin Socket Diagram for ECU Communication Issue So one pin is not connected in the cube anyway, connect as in the above picture and what are you trying to connect?
    mario 77
    Help: 66
    Rate: 335
    Check that there is ground on the middle pin.
  • #4 16363500
    strazak2000
    Rate: 8
    cdifem 3 expert
    and the autocom, no communication, more needs a diagram where which wire goes in the bundle. and can the immo affect the lack of communication ??? as far as I know it is removed.
  • #5 16363511
    krystek86
    Rate: 30
    removed immo should not affect communication, wires from the plug should go to the ECU
  • #6 16363542
    strazak2000
    Rate: 8
    just that one white and yellow goes to the cabin and when I found the same in the plug, there is no passage but I'm not sure if it's the same. it is best if I have a diagram or know which pin in the cube is from the k line of the l line someone will help? and if this white and yellow goes to the cabin, can I connect it immediately with ecu ??
  • #8 16363638
    strazak2000
    Rate: 8
    I saw this diagram, but I do not see the 3-pin cube here
    and the lack of the clutch pedal sensor nothing to do with it ??
    Added after 1 [hours] 30 [minutes]:
    bosch 0 281 010 486 needs a pin description for such a computer
  • #9 16363816
    KarizmoGSM
    Help: 95
    Rate: 292
    It is not possible to connect to the controller, even if you have everything unplugged, all you need is mass, plus and the K line, there you have EDC 15c7?
    KariMax Paweł Kalkowski
    Kronikarska 8, Łódź, 92-624 | Company Website: www.cfiat.pl
  • #10 16363845
    strazak2000
    Rate: 8
    I think it's d2841hc
    Fiat Ducato 2.8 jtd 2001 - OBD1 3-Pin Socket Diagram for ECU Communication Issue this is my computer
    I know that the k line goes to pin 7 I think I'm wrong ??? and where is the l line?
    KarizmoGSM
    Help: 95
    Rate: 292
    Don't make it up, this is EDC 15c7 and there is no L
    • Fiat Ducato 2.8 jtd 2001 - OBD1 3-Pin Socket Diagram for ECU Communication Issue Alfa_EDC15C7.jpg (99.47 KB) You must be logged in to download this attachment.
  • #12 16363869
    strazak2000
    Rate: 8
    k line to which pins when dripping? and line l where with the drip?
    Added after 59 [seconds]:
    nowhere does it write that it is edc 15c7
    and if there is no l line, it will normally connect to the computer ??
    Can I change the 3 pin socket to OB 2 and it will work ??
  • #13 16363885
    KarizmoGSM
    Help: 95
    Rate: 292
    Not all have L lines, it will work on the K line itself, it does not write on the controller but this is what I say, yes you can as long as the power, ground and K line were in the right place in OBD
  • #14 16363892
    strazak2000
    Rate: 8
    and the usual cdief 3 will embrace it ??
  • #15 16363950
    krystek86
    Rate: 30
    will embrace and autocom delphi
    KarizmoGSM
    Help: 95
    Rate: 292
    Sure, possibly multiecuscan
    I do this for the kilograms.
The discussion revolves around a communication issue with the ECU of a 2001 Fiat Ducato 2.8 JTD, specifically related to a damaged 3-pin OBD1 socket. Users provide various suggestions, including checking the ground connection on the middle pin and ensuring proper wiring to the ECU. The author seeks a detailed pin diagram for the 3-pin socket, expressing concerns about the immo system's impact on communication. Responses clarify that the immo should not affect communication and emphasize the importance of the K line for ECU connection. Users discuss the possibility of converting the 3-pin socket to OBD2 and confirm compatibility with diagnostic tools like CDiag 3 and Autocom Delphi.
