Bypass Printer Lock for Replacements: HP Ink Advantage 2545 Network Connection
eryk.tomaszewski 11901 5
  • #1 16363473
    eryk.tomaszewski
    Rate: 69
    Hello. Do you have an idea how can I bypass the printer lock for replacements ?,
    HP Ink Advantage 2545 printer connected over the network.
  • Clean cartridge contacts and refill dried cartridges
    #2 16363585
    heniek 1591
    It seems to me that the HP Ink Advantage 2545 printers do not have any locks to the cartridges of the ink cartridges. If there is a problem with the ink, remove the container and clean the contacts, eg with a pencil eraser, and re-insert the container. If the dry container is topped up with ink using a syringe. This should help if you do not need to buy, for example, a black ink cartridge CZ 101AE HP650 (in the price of about PLN 35) and after the trouble.
  • #3 16363640
    hernan_cortes
    Help: 55
    Rate: 97
    The replacement will not work if it was previously used in the printer where container protection was enabled.
  • #4 16363758
    eryk.tomaszewski
    Rate: 69
    I found this ocornę, and by default I have it turned off. and I do not want to print any more. what to do with this?
  • Cartridge protection or electrical damage requires seller complaint
    #5 16364131
    hernan_cortes
    Help: 55
    Rate: 97
    But it is not the most important that you have "container protection" turned off. If someone in front of you used this ink cartridge in his printer and had this feature active then this ink container will work only in his printer. It is also possible that the ink container is electrically damaged. The only advice is to file a complaint with the seller.
  • #6 16365230
    eryk.tomaszewski
    Rate: 69
    Oh, I understand. all clear.
