Seat Leon Vibrations During Braking: Replaced Ferodo Discs, Pads, Hubs, Joints & More
pawlak995_95 5190 5
  • #1 16367075
    pawlak995_95
    Hello. The car started to vibrate on the steering wheel and the whole car during braking. I have replaced all ferodo discs and pads. It was wonderful for a few days. But again, the problem came back. The hubs are ok. Let me add that I have a little play on the mangle. And for rubber replacement and stabilizer links, rear rocker sleeves and pins. Tires ok, rims also and everything balanced. I recently replaced the joints. These vibrations are annoying. Do you have any ideas? ?
  • #2 16367113
    1megan
    Rate: 40
    Hello, the front shields are bent
  • #3 16367137
    drdrug
    Help: 25
    Rate: 178
    I suggest driving to a diagnostic station and checking the ovality of the front axle. Transfer the wheels from the rear to the front. How do you know hubs are ok? I had two sessions with such a case, leona 1 gen, toledo 2gen, dials changed twice a month. Replacing the hubs solved the problem.
    Discs and blocks from the store or the Internet?
  • #4 16367220
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Look for play in the suspension. Remove them and it should be ok.
  • #5 16367329
    ociz
    Help: 1379
    Rate: 3486
    pawlak995_95 wrote:
    to be replaced ... rear bushings on rocker arms and pins.
    You have answered yourself where these vibrations come from.
  • #6 16368624
    pawlak995_95
    Aledrogo discs, hubs were replaced last year Seat Leon Vibrations During Braking: Replaced Ferodo Discs, Pads, Hubs, Joints & More
    Added after 42 [seconds]:
    On the other hand, this sleeve is more torn
