Seat Leon 1.9 TDI 90 - Vacuum Loss, Power Issues: Replaced Valves, N75 Valve, Hose Checks
Superbad17 7017 7
  • #1 16376252
    Superbad17
    Hello, the lack of power problem.
    I have already replaced the valves and still no power. However, I checked that the barbell from the pear and the barbell from the extinguishing flap did not move during firing. In comp. Shows undercharging, TC fault valve.
    I have no idea what to do next. Lubricate the N75 valve, I replaced the hoses.
  • #2 16376270
    andrzej20001
    Help: 1578
    Rate: 6669
    Vac pump OK? the brake is ok? If it does not suck, it is easy to find the fault. Tubing, tube and mouth. :)
  • #3 16376553
    Superbad17
    What brake?
    From the n75 valve, I also do not feel anything continuous.
    How to check the vac pump? Detach the hose?
  • #4 16376575
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    When the vacum pump does not work, the brake servo does not work, so the brakes are very weak.
    Do not look at the vacuum behind the N75, just look at the vacuum before.
    You have a description on it. There should be VAC written there and there should be a vacuum on this hose after firing.
    You can check it with a vacuum gauge or as an amateur, using language.
  • #5 16376837
    Superbad17
    The vac pump is working. The hose to the valve was slightly clogged, after removing the muck, the valve is pulling but the problem is still there. Should there be a vacuum in all these hoses? And can they be checked in the same way? In the attachment there is a photo of some element to which the vacuum tube goes, but the end of "summer" is loose. From this [Xxxx] the hose goes further to the extinguishing flap bar. That way, maybe pinch the pressure? What is this
    I deleted the obscene. [T5]
    • Seat Leon 1.9 TDI 90 - Vacuum Loss, Power Issues: Replaced Valves, N75 Valve, Hose Checks 1490706556473-1307841377.jpg (367.8 KB) You must be logged in to download this attachment.
  • #6 16376985
    grala1
    Help: 1495
    Rate: 5052
    There should be a vacuum in the hose that supplies the valve, be it a turbine valve, EGR valve or a damping flap. The engine controller decides whether there is negative pressure at the output.
    If you had muck in the hose, maybe it's in the valve.
    The pear may have holes in it.
    This valve in the photo is rather a valve from the extinguishing flap.
    From the turbine and EGR, it should have a third hose that should go to the air filter, but nothing will happen if it is not connected.
    It would be nice to do a dynamic log 11 and 11BS where you can see if the bar is moving and then you can create a negative pressure.
    You can also give a negative pressure directly on the pear without bypassing the valve and then the pear should move the barbell, and if it does not, it has a hole in it or too little negative pressure.
  • #8 16379250
    grala1
    Help: 1495
    Rate: 5052
    If there was negative pressure in this conduit and the bar does not move, then: a blocked conduit, a hole in the bulb, a blocked turbine bar.
    Try to move the barbell by hand.
    See if the tubing is patent and if the coo is leaky, you can check it with a larger syringe.
The discussion revolves around a Seat Leon 1.9 TDI 90 experiencing power loss despite replacing various components, including valves and hoses. The user reports that the vacuum pump is operational, but the N75 valve does not exhibit continuous suction. Responses suggest checking the vacuum lines for blockages and ensuring that the hoses connected to the EGR valve and turbine are functioning properly. A "pear" test indicates that the vacuum actuator does not move, leading to further investigation of potential blockages or leaks in the system. Dynamic logs were recommended to assess the movement of the barbell and diagnose the issue more accurately.
