Audi A4 B5 Lift - Experiences Post Replacement of Ferodo Shields and Delpchi Pads
7341 11
Why are my Audi A4 B5 brakes smoking and showing 106–124°C after replacing the brake shields and pads?
Not necessarily: 106–124°C after a short drive is not an alarming brake temperature, but visible smoke from the shields means the brake area should be inspected for rubbing or contamination [#16802985] A new pad/shield set should be working at full efficiency after about 10 km [#16802985] Normal braking can already heat the shields to around 70–100°C after a few minutes of driving, and repeated braking can push brake temperatures much higher, even toward 300°C in hard use [#16803027] [#16803104]
  • #1 16802719
  • #2 16802741
    moto-kord
    Help: 137
    Rate: 505
    mihal2002 wrote:
    I replaced the shields (ferodo) and pads (delpchi)
    The guides have been cleaned - the brake piston has moved back easily.
  • #3 16802757
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Have you looked at the yoke or are there no holes?
    Anyway, they must arrive.
  • #4 16802781
  • #5 16802783
    kkknc
    Help: 1915
    Rate: 6709
    When you use the brakes, the temperature rises. So if you don't take it into account with your driving style, it's none of that.
    I just hope that you submitted according to the art and checking the components before assembly took place.
  • #6 16802796
  • #7 16802985
    ociz
    Help: 1379
    Rate: 3486
    124 degrees is a low temperature. If you smoke from the shields with this one it means that they are stained.
    mihal2002 wrote:
    How long should they last?
    As a new set, after 10km they should work with full efficiency.
  • #8 16803011
  • #9 16803027
    kkknc
    Help: 1915
    Rate: 6709
    mihal2002 wrote:
    Maybe someone from the industry speaks.
    No reference point. Two times in a row you will keep 50km / h and it's not very intense and you have as soon as you measure such a temperature.
    General shields around the city catch some 70-100 degrees after a few minutes of driving.
  • #10 16803030
    szymitsu21
    Help: 343
    Rate: 1300
    mihal2002 wrote:
    I made 40 and I think the temperature is too high
    120 ° is too much?
    one braking from 50km / h to 0 in 100% functional braking system probably generates a similar temperature or higher.
  • #11 16803061
  • #12 16803104
    szymitsu21
    Help: 343
    Rate: 1300
    mihal2002 wrote:
    szymitsu21 wrote:
    120 ° is too much?
    I do not know. So I asked HERE. And what can they achieve safe?
    "if someone thinks that 250 degrees C. is a very remote value that you will never reach in your car during braking, then we provide: long braking, for example on a long descent at a speed of about 80 km / h in a few minutes will lead our car brakes to the aforementioned limit To put it even simpler: it is enough to accelerate the car to 60 km / h three times on an even road and brake it to a standstill to reach the temperature limit of 300 degrees C. "
    So on quickly.
The discussion revolves around the experiences of an Audi A4 B5 owner after replacing Ferodo brake shields and Delpchi brake pads. The user reports that after a test drive, one wheel exhibits easier use of the brake pedal and emits smoke, with temperature readings of 124°C and 106°C from the brake dials. Responses from other users suggest checking the brake components, including the yoke and piston movement, and emphasize that while brake temperatures can rise during use, the observed temperatures are relatively low. Concerns are raised about potential corrosion on the pistons and the overall functionality of the braking system, with some users noting that temperatures can reach up to 250°C during intense braking. The user seeks confirmation on whether the observed conditions are normal and how long the new pads should last.
TL;DR: Brake discs can reach ~300°C after three 60→0 km/h stops; “it is enough to accelerate to 60 km/h three times.” Light smoke or 124°C readings soon after a pad/disc swap usually point to bedding-in or minor contamination, not failure. [Elektroda, szymitsu21, post #16803104]
Why it matters: This FAQ helps Audi A4 B5 owners diagnose hot brakes, light smoke, and uneven temperatures right after replacing pads/discs, and explains what’s normal vs. what needs fixing.
Is ~120–125°C rotor temperature normal right after a pad/disc replacement?
Yes. A single hard stop can generate similar or higher temperatures in a healthy system. 120°C alone is not alarming. Focus on consistent braking feel, no pulling, and equal wheel rotation when lifted. If temps keep climbing without braking, investigate caliper drag or contamination. [Elektroda, szymitsu21, post #16803030]
Why do I see light smoke or smell after my first test drives?
Light smoke often comes from residue or contamination on new discs/pads. The temperature you measured (e.g., ~124°C) was called low, so the smoke likely isn’t from extreme heat. Clean mating surfaces during install and bed the pads correctly to burn off residues. If smoke persists after bedding, recheck for grease or fluid on friction surfaces. [Elektroda, ociz, post #16802985]
How long until new pads ‘bed in’ and stop feeling weak or grabby?
A fresh set should reach full efficiency after about 10 km. During bedding, slight drag and mild odor can occur but should diminish quickly. Avoid long, continuous braking on the first few drives; use several moderate stops from safe speeds. Verify smooth pedal feel and no wheel lockups. [Elektroda, ociz, post #16802985]
What rotor temperatures should I expect in city driving?
Typical city use brings discs to roughly 70–100°C within a few minutes. Short stops and lower speeds keep temps in this range. Longer descents or repeated hard stops will push temperatures higher. Monitor for symmetry side-to-side; large persistent differences suggest drag or contamination. [Elektroda, kkknc, post #16803027]
Why do brake temperatures rise so fast?
Brakes convert kinetic energy into heat. As one expert put it: “When you use the brakes, the temperature rises.” Repeated decelerations stack heat faster than the system can shed it, especially with limited airflow. Plan cool-down coasts between hard stops when testing new pads. [Elektroda, kkknc, post #16802783]
One wheel reads hotter than the other—what should I check first?
Start with clean, dry friction surfaces. If you see smoke, pads or rotors may be contaminated. Confirm the caliper slides freely and the piston retracts smoothly. Unequal temps after equal driving usually mean drag on the hotter side. Address contamination or sticking hardware before further testing. [Elektroda, ociz, post #16802985]
Should the wheel spin completely free after installing new pads?
Expect slight resistance at first. New pads need to ‘arrive’ (bed to the rotor surface). A light, even drag that reduces after several drives is normal. Persistent heavy drag or a wheel that’s hard to turn indicates sticking slides, twisted hose, or a seized piston. [Elektroda, Strumien swiadomosci swia, post #16802757]
Could a nearly fully extended piston corrode and then stick afterward?
Yes. If a piston spent time near its travel limit, corrosion can form beyond the usual sweep and later cause sticking. This presents as hot brakes, uneven temps, or a dragging wheel. Inspect boots, piston finish, and retraction. Replace or rebuild if pitting is present. [Elektroda, 1098678, post #16803011]
How do I check for sticking guide pins or a lazy caliper piston (3 steps)?
  1. Lift and spin the wheel; compare resistance side-to-side.
  2. Remove the caliper; verify pins are clean, straight, and greased correctly.
  3. Retract the piston; it should move back smoothly and evenly without force spikes. [Elektroda, moto-kord, post #16802741]
What is the caliper yoke, and should it have holes?
The yoke (carrier) holds the pads and guide pins. Inspect it for proper hardware, clear passages, and no blocked holes or burrs. A dirty or damaged yoke can cause pad hang-up and heat. Clean the carrier and ensure pads slide freely in their channels. [Elektroda, Strumien swiadomosci swia, post #16802757]
Are my install steps OK if the piston didn’t retract easily at first?
The piston should retract easily and evenly. If it resists, stop and address dirt, corrosion, or misalignment. Forcing it risks seal damage and future drag. After cleaning guides and confirming smooth piston movement, reassemble and perform a controlled bedding sequence. [Elektroda, moto-kord, post #16802741]
How hot is too hot on a long downhill or repeated hard stops?
Sustained braking on descents or repeated 60→0 km/h stops can drive discs toward 250–300°C. Reserve gears and intermittent braking help control heat. If you feel fade, lengthen cool-downs and inspect pads for glazing before continuing aggressive use. [Elektroda, szymitsu21, post #16803104]
Which brands were mentioned, and do brands change rotor temperatures?
The thread mentions Ferodo shields and Delpchi pads. Initial heat and light smoke relate more to bedding, cleanliness, and free-moving calipers than brand choice. Verify correct installation and condition first; then evaluate pad compound if issues persist. [Elektroda, 1098678, post #16802719]
