Iveco Daily 2008 3.0d - Turn Signals, Emergency & Other Lights Not Working, Need Wiring Diagram
decybel91 13563 5
  • #1 16368087
    decybel91
    Help: 1024
    Rate: 4231
    The car is Iveco Daily 2008 3.0d.
    Turn signals, emergency and other lights do not work approx.
    I would need even a shortened diagram, because someone had buried it in front of me.
    Ok switch, body comes out, but wants to double check.
    The post was reported. Edited [T5]
  • #2 16368532
    miler80
    Help: 272
    Rate: 1395
    More like a switch, or the lack of one power supply because the body for this ailment is rather unlikely.
  • #3 16373100
    decybel91
    Help: 1024
    Rate: 4231
    The scheme is still in demand. greetings
  • #4 16373933
    rumot102
    Rate: 31
    Often times the emergency switch is raining heavily and there are no emergency directions
  • #5 16377508
    citromaniak
    Help: 53
    Rate: 394
    buddy, give me priv, I have some schemes for daily
    Moderated By T5:
    And what does this valuable post bring to others?
  • #6 16386013
    decybel91
    Help: 1024
    Rate: 4231
    In the end, as I assumed, the Body was damaged (damaged board in this gray housing). I do not thank all the matiz and lanos specialists on this forum.
