Seeking Connection Diagram for Left-Right Control on Contactors for 3-Phase Motor
tokinstalator 10587 5
  • #1 16368265
    tokinstalator
    I have a 3-phase motor, I need to do left-right control on the contactors.
    I am asking for help and connection diagram.
  • #2 16368349
    stanislaw1954
    Help: 2013
    Rate: 4676
    The subject has been raised many times, and you will definitely find it in Google. You just have to search.
  • #3 16368357
    tokinstalator
    Thank you for your comprehensive answer.
    3.1.16. Before publishing an entry, the User is obliged to check using the Forum search engine whether a given problem has already been raised.
    Moderator Krzysztof Reszka
  • #4 16368375
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    Alternatively, you can add a third contactor that switches on the power supply circuit.
  • #5 16368402
    kortyleski
    Help: 957
    Rate: 3860
    And a time block. Shifting the rotations on the accelerated engine will probably cause the protection to work.
  • #6 16403931
    tokinstalator
    Thank you for your help. topic resolved
