How can I wire a 12 V motor for left/right direction control without causing a short circuit?
Your current wiring is making a short circuit; to reverse a 12 V motor you need an H-bridge or a proper reversing switch, not a simple two-position On/On switch [#16548286][#16548280][#16548310] If you use a reversing switch, connect the supply to the center terminal and the left/right outputs to the motor, but add a separate power switch so the motor can be turned off completely [#16548308][#16548397] A switch with three positions is also suggested as a better option for direction control [#16548420]
Hello, I want to do engine control left right. I connected everything as in the picture above, but it doesn't work. What do you have to do to make it work?
Draw a decent diagram of how you connected it, because here you can not see anything, and I do not think that it has the right to work. To control the direction of rotation of the motor, the H bridge is most often used.
If it is two-way it will be, but the connection is bad. Center feed, left / right on the sides of the exit. And this switch has two positions - On / On. So the engine will run all the time.
The discussion revolves around troubleshooting connection issues for a 12V motor driver intended for left-right control. The user initially shared a diagram but was advised to provide a clearer schematic. Responses highlighted the risk of short circuits due to improper switch connections. Suggestions included using a double switch to control motor direction and ensuring a complete power cutoff. A three-position switch was also recommended for better control. The user confirmed that they resolved the issue after considering the advice given. AI summary based on the discussion. May contain errors.
