VW Golf 4 - Lock failure. Does not open from the outside and from the inside.
sebabana11 5763 13
How can I open a VW Golf 4 rear door lock when it will not open from either the outside or the inside?
Remove the inner metal sheet by drilling out the three plastic rivets/pins (about 5 mm), then screwing a 6 mm tap into each hole and pulling the pins out; after that, push the sleeves inward, disconnect the wires/cable, and you can access the lock mechanism from inside the door [#16373762] On Golf/VW locks the child lock does not solve this problem, and removing the trim alone will not unlock the door, so you must manually move the lock’s horizontal bar/lever to the left or help the locking lever return [#16371125] [#16374156] [#16374377] If you can reach the actuator, briefly applying external power to the lock motor was also suggested as a test [#16374164]
  • #1 16370809
    sebabana11
    I have a problem with the lock in the rear right door of golf 4. In the morning my son opened the door and when I wanted to release it I could not open it. From the inside, you can't do it because the lock is on. I am at the stage of removing the sheet from the glass. Plastic pin from the glass removed and I think I can do nothing more. I can't take it off because I would have to unscrew the lock firmly to remove the locking rod. Will anyone help what next? The white circle from the motor from the lines will also fall out, it will be a problem to fold it as the metal sheet will dismantle.
    • VW Golf 4 - Lock failure. Does not open from the outside and from the inside. 20170325_154624_HDR.jpg (3.85 MB) You must be logged in to download this attachment.
    • VW Golf 4 - Lock failure. Does not open from the outside and from the inside. 20170325_154614_HDR.jpg (2.85 MB) You must be logged in to download this attachment.
  • #2 16371125
    Staszek49
    Help: 228
    Rate: 1139
    You probably have the option of opening the door - pull the horizontal bar to the left. If you have the so-called "parental lock", you may be able to unlock the lock after lifting the "sheet" and pulling (moving) the corresponding element of the lock, cooperating with this external "tongue" lock.
  • #3 16372387
    sebabana11
    I tried and I can't put my hand there. I don't know if I can drill these three plastic rivets? I guess I'll have to give it to a specialist. Maybe those who replace the car windows.
    • VW Golf 4 - Lock failure. Does not open from the outside and from the inside. 20170326_113317_HDR.jpg (3.07 MB) You must be logged in to download this attachment.
  • #4 16372610
    Hektar Zahler
    Help: 230
    Rate: 527
    Tell me if you hear the actuator from the remote control.
  • #5 16372637
    sebabana11
    I don't have a remote control. I close and open the key.
  • #6 16372704
    Hektar Zahler
    Help: 230
    Rate: 527
    Then listen to the key and tell him about it.
  • #7 16373762
    FAB 2002
    Help: 35
    Rate: 195
    These three plastic pins can be pulled out easily. You need to centrally drill a hole in each of them with a drill bit 5 mm. Then screw the tap into this hole. 6 mm. and slowly pull the pin out. After removing the pins, push the protruding sleeves inward. Then you can remove this disc. Of course, you still need to disconnect the wires and the cable. If your car has locking locks, you will have to get a little tired to open them.
  • #8 16374156
    piotrekwoj1
    Help: 939
    Rate: 3401
    Golf and every VW from the machine bolts the locks, removing the plate will not give him anything, even the parental lock will not remove.
  • #9 16374164
    Ireneo
    Help: 746
    Rate: 2461
    Knock out these three plastics normally. Briefly give the engine a few times the power supply, it may surprise. Remember that when feeding it was disconnected from the car installation.
  • #10 16374165
    piotrekwoj1
    Help: 939
    Rate: 3401
    Provided he knows which pins to give.
  • #11 16374377
    Hektar Zahler
    Help: 230
    Rate: 527
    That's exactly how it is. Locking from the machine, and unlocking in two. This lever does not bounce and you need to help her to figure it out - link .
    There are two motors and they have pins on the pins, but if you don't know what to do with them, I wouldn't go crazy.
    Moderated By T5:
    The post was reported.
    There is one engine in the castle.
    3.1.11. Do not send messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • #12 16379463
    Hektar Zahler
    Help: 230
    Rate: 527
    Perhaps who will remember it. What I saw two.
  • #13 16379508
    sebabana11
    This week I work until 19 and I don't have time to take care of it. At the weekend I will try and if I fail then I call the company that opens the locks.
    Thanks to everyone for the answers.
  • #14 16379749
    Ireneo
    Help: 746
    Rate: 2461
    I don't know how to open locks.
✨ The discussion revolves around a lock failure in the rear right door of a VW Golf 4, where the door cannot be opened from either the inside or outside. The user has attempted to remove the door panel but is struggling with the lock mechanism. Suggestions include checking for a "parental lock," drilling out plastic rivets to access the lock, and ensuring the actuator is functioning. Some users recommend consulting a specialist for assistance, especially if the user lacks experience with car locks. The conversation highlights various methods to troubleshoot and potentially resolve the locking issue.
