MAN TGL 12.220 Euro 5 (2011): ABS Indicator Light, Weak Braking, Fehlercodes 06005, 06016, 03001
AdamKesy 16314 17
Why does my 2011 MAN TGL 12.220 Euro 5 get ABS and brake-fault warnings after 30–40 km and then lose braking power, with codes 06005, 06016 and 03001?
The fault codes 03001 and 06016 point to a defective ABS/EBS controller or its integrated Wabco main brake valve, which matches the ABS warning and very weak brakes [#16471013][#16474367] On the MAN TGL, the ABS valves are integrated with the main brake valve under the hood on the driver’s side [#16476793] Before replacing parts, do a full diagnostic and isolate the external sensors/valves by unplugging them to see whether 3001 remains, because that helps confirm whether the controller itself is faulty [#16479279] One reply also notes that 3001 can mean an internal microcontroller/RAM/ROM self-test failure and that the EBS controller may need replacement [#16474769] In the end, the problem was solved by regenerating the Wabco main brake valve [#16629006]
  • #1 16470871
    AdamKesy
    Rate: 9
    I have a problem with MAN TGL 12.220 euros 5 from 2011, the car was working all the time, and until last week where after driving about 30-40 km the ABS indicator lights up displays the message Storung Bremsterung and the brakes virtually disappear, brakes very weakly, it helps to turn it off and on again ignition, but it's also for a while. I checked all the cubes in the front under the board by the wheels and it is ok. The computer shows errors 06005, 06016 and 03001
    Please help
  • #2 16471013
    onepiotr
    Help: 55
    Rate: 218
    03001 - damaged ABS driver. Symptoms match the fault.
  • #3 16472368
    AdamKesy
    Rate: 9
    And where is the ABS driver in MAN or is it perhaps the modulator on the back?
  • #4 16472425
    darfur5
    Help: 267
    Rate: 1708
    Unless I'm mistaken it's in front under the brake valve. Open the hood and there you will find it, on the driver's side.
  • #5 16473053
    AdamKesy
    Rate: 9
    welcome back
    So it's the Wabco brake master valve anyway? if so, is it possible to repair this regeneration or only to replace it?
  • #6 16473239
    onepiotr
    Help: 55
    Rate: 218
    The controller is in the passenger side of the cabin. Before making any decisions, you would need to do a full computer diagnosis to find out what the problem is and what to fix. An internal error (if the interpretation of the fault is correct) means a faulty driver (ABS computer) and not a valve.
  • #7 16473253
    saron22
    Trucks specialist
    Help: 308
    Rate: 1602
    The controller is under the main brake valve on the driver's side and not in the passenger's side of the cabin. This is TGL and not TGA.
  • #8 16473263
    onepiotr
    Help: 55
    Rate: 218
    Aaa to sorki: / They come to me already dismantled.
  • #9 16473322
    AdamKesy
    Rate: 9
    welcome back
    I am after replacing the modulator on the rear axle driving 35 km and again ABS lit up German messages and errors 6005 6016 3001 597 and brakes missing - any ideas?
    Added after 5 [hours] 49 [minutes]:
    One more question when changing the entire service brake must be the same numbers as in the predecessor, can you replace it with another Wabco? mine has the numbers 81521306305 4800200210
  • #10 16474367
    darfur5
    Help: 267
    Rate: 1708
    Error 6016 is message ZBR 2 loss of ABS signal. So there may be an end to the ABS driver. If this error has repeated, then you have unnecessarily replaced the modulator and drowned the money.
  • #11 16474769
    gucio~1
    Help: 61
    Rate: 313
    Unknown interrupt or unknown microcontroller self test, RAM or ROM test - device defective
    Code: 3001.9
    - Check the front axle ABS valves for signs of unacceptable corrosion, replace the valves if necessary (note: from version CBU 480 020 020 0 this first check may be omitted).
    - Replace the EBS controller
    Where did the idea to replace the rear axle modulator come from?
  • #12 16476765
    AdamKesy
    Rate: 9
    The modulator was out of stock, we changed it, it was also cost-free, and the ABS valves on the front axle are they located in TGL?
  • #13 16476793
    saron22
    Trucks specialist
    Help: 308
    Rate: 1602
    ABS valves are integrated with the main brake valve, i.e. the one under the brake pedal under the hood.
  • #14 16476891
    svavecone
    Help: 73
    Rate: 455
    Unplug, check, the "redundant" valve (I do not know the Polish description), which is located at the rear axle on the left side of the vehicle. It has a plug with only 2 pins. After replying, see if the errors are the same as before.
    For testing purposes, you can plug in a normal 2/3 valve that has a similar resistance.
  • #15 16477348
    onepiotr
    Help: 55
    Rate: 218
    Gentlemen.
    Straighten me up because I'm not overwhelmed. There is a 3001 error - the ABS driver is damaged, so why replace the valves, modulators and everything else. A damaged valve causes another fault. Here even ZBR informs about the lack of data from ABS. ..?
  • #16 16479279
    svavecone
    Help: 73
    Rate: 455
    I can't explain it 100% but it is related to the power distribution in the EBS controller. If the same source is used to power many components and one of them fails, e.g. has too much power, the supply voltage is much lower than required. He often shoots a fuse ... but he doesn't have to. EBS is such a system that it does not always tell exactly where it hurts, and as it is already said, the reason may lie elsewhere.
    So it's best to unplug all external sensors / valves ... and then read the errors, there will of course be a lot about disconnected plugs, but if you still have the same 3001 then you are sure of the controller itself.
  • #17 16479612
    onepiotr
    Help: 55
    Rate: 218
    svavecone wrote:
    svavecone
    I agree. Sometimes it happens and then, for example, I recommend connecting the rear modulator to class 15 to read the reason for disconnecting the rear power supply. But in such cases I have not encountered internal errors of the central unit and eeprom at once.
  • #18 16629006
    AdamKesy
    Rate: 9
    problem solved, it turned out Wabco (main brake valve) regenerated and works as it should be thanks for help
✨ The discussion revolves around issues with a 2011 MAN TGL 12.220 Euro 5 vehicle, specifically concerning the ABS indicator light activation, weak braking, and error codes 06005, 06016, and 03001. Users identified that error 03001 indicates a damaged ABS driver, while error 06016 suggests a loss of ABS signal. The ABS driver is located under the brake valve on the driver's side. A user replaced the rear axle modulator but continued to experience issues, leading to further diagnostics. Ultimately, the problem was resolved by regenerating the Wabco main brake valve, restoring proper functionality.
