VW Caddy 1.6tdi: Duration and Completion of Minimum Dose VCDS Adaptation Procedure
kowalwalcz 21903 4
  • Minimum dose adaptation duration and completion behavior
    #1 16373225
    kowalwalcz
    Help: 9
    Rate: 10
    Hello all,
    I would like to perform the minimum dose setting procedure via VCDS. The patient is VW caddy 1.6 tdi. I enter the engine controller then BASIC SETTINGS, I choose the minimum dose adaptation procedure, the program asks you to press the brake and gas pedal and hold them. Everything ok just ...
    How long does this procedure take? After an hour of adaptation, I gave it up, they still had the program. How should this procedure end? Someone did the adaptation?
  • #2 16738912
    vincente00
    Hi, did you manage to get the minimum dose? I also had and did not finish the procedure successfully.
  • #3 16738921
    kowalwalcz
    Help: 9
    Rate: 10
    Unfortunately it didn't work out
  • #5 16739659
    kris-644
    Help: 39
    Rate: 74
    I used vag can pro once.
