Toyota Yaris 2007: CD Player Stuck with Error 3 - Internal Fault & Removal Process
werka123 7233 6
  • #1 16375313
    werka123
    Hello, I recently bought a used Toyota Yaris 2 from 2007, the radio receives everything nicely, but when I put my CD into the player it ate it and I did not want to return or turn on anything and it was written error 3. I checked it and it means that "it signals an internal fault of the device . you need to take it out again and insert the disc or the changer "only there is a problem because I don't know how to get out, will someone help?
  • #3 16375339
    werka123
    does not work; / and I mean, I want to go to the mechanic because if I fix it, he will turn on the song quite controversial and this is my neighbor: /
  • #4 16375348
    sosarek
    Help: 9318
    Rate: 15512
    So disassemble the radio yourself and take out the disc. Can you hear the mechanism at all when you try to switch to CD, try to eject the disc?
    Z
    Pka, Poznań, 60-850
  • #5 16375350
    werka123
    so you hear the noise as if you wanted to load but can't, after a while error 3 pops up.
    and how to do it easily and efficiently? I'm a typical layman when it comes to dismantling this kind of thing
  • #7 16375379
    werka123
    thanks a lot!
✨ The discussion revolves around a 2007 Toyota Yaris experiencing an "Error 3" message on its CD player, indicating an internal fault after a CD was inserted. The user reports that the disc ejection button is non-functional and seeks assistance in removing the CD. Responses suggest attempting to disassemble the radio to retrieve the disc, with one user noting that the mechanism makes noise but fails to load the CD. The user expresses a lack of technical skills and considers visiting a mechanic for help.
