MAN TGX 18.440 2008 EBS5 System - Uneven Braking Towards Left Front Wheel
wit-trans 9057 13
Why does a MAN TGX 18.440 with EBS5 pull strongly to the left when braking, with the left front wheel braking too hard?
The fault turned out not to be the front axle itself but an intermittent EBS 01056 error that was related to the trailer brake control valve; when that valve was finally replaced, the error disappeared and the tractor’s front axle began braking normally again [#16420368] Before that, the thread suggested checking the brake actuators/cylinders by comparing left and right pressures, because a defective actuator or a broken internal spring can cause one side to brake differently [#16377290][#16379929] A roller test was also recommended to confirm which side was actually braking unevenly [#16380795][#16382279]
  • #1 16376205
    wit-trans
    Rate: 68
    Hello, MAN TGX 18.440 2008, the ebs5 system, when braking (driving with the tractor and with the semi-trailer too) pulls strongly to the left, the left front wheel takes too much, Discs ok, pads too, calipers too, pads wear evenly, errors in There are no systems, I think to measure the pressure in the actuators, but I do not know what it should be, maybe someone, so what may be the reason.
  • #2 16376456
    Cobrat
    Help: 35
    Rate: 501
    Since you are sure of the caliper, I think that the brake cylinder itself is defective or the EBS modulator.
    In pneumatic brake systems, the air pressure is standardized and amounts to 0.8 MPa. However, I think that the modulators, depending on the vehicle load, regulate the braking force, thus also the pressure going to the actuator. If I am wrong, somebody correct me ;) .
  • #3 16377290
    darfur5
    Help: 267
    Rate: 1715
    Remove the right-hand actuator and check that it is working properly. Sometimes the spring breaks in the actuator and the spindle does not extend all the way.
  • #4 16377795
    wit-trans
    Rate: 68
    ok.I will check this right cylinder when it comes back from the route, I will also measure the pressures in the right and left cylinders (for comparison)
  • #5 16379929
    Wojtek00321
    Rate: 31
    Most of the time, the actuator blew out inside. I suggest replacing it.
  • #6 16380239
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    Or maybe it's right that does not inhibit? Better go inline skates and check the brakes before you start fumbling with the wrong wheel. On the other hand, if it wears the pads evenly, it may be the reason for the geometry, i.e. more play and it loses its geometry during braking.
  • #7 16380598
    wit-trans
    Rate: 68
    ok.I will ride the rollers and then measure the pressure in the cylinders, the driver's report shows that the left one brakes too much, because when it rides in the rain, it blocks it and the ABS releases the wheel, and in the right one it does not happen, as if the air pressure in the the left actuator in relation to the right one, maybe it is the abs valve near the wheel, but the error is not burning
  • #8 16380678
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    wit-trans wrote:
    The driver's report shows that the left one brakes too much, because when it rides in the rain, it blocks it
    First, let him learn to drive. Wet and wet - it can be different. I also heard such reports of drivers from me. When I did the investigation, it turned out that the cars are ok, only one driver wanted the bus to stop like a passenger car and in the other he was right because the tires were some dirty, they did not stick to the asphalt in the wet. If one wheel does not brake, especially at the front, it will turn the steering wheel even with light braking.
    Check the bearings in the wheels, maybe one has play and the wheel speed sensor reads the speed incorrectly and hence the ebs interfere with braking, although it should not.
  • #9 16380713
    wit-trans
    Rate: 68
    The driver is right, I drove myself and even when he brakes the tractor lightly, it pulls to the left, the bearings are checked for play, there is no
  • #10 16380795
    MobilTruck
    Help: 139
    Rate: 965
    And this is where I would start. If the braking turns out to be equal, the wheel spacer to the right side and the road test.
  • #11 16381613
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    What about the back? It occurred to me that the horse is short and if one you is not braking, it can pull off quite a bit ...
  • #12 16382279
    darfur5
    Help: 267
    Rate: 1715
    wit-trans wrote:
    from the driver's account it follows that the left one brakes too much, because when it rides in the rain, it blocks it and the ABS releases the wheel and in the right one it does not happen, as if the air pressure in the left cylinder is too high in relation to the right cylinder, maybe it is the ABS valve at wheel, but the error does not burn
    So the cause is in the right wheel. The roller test will not hurt. Regarding the response of the ABS system; if there was something wrong with it, it would definitely show an error on the desktop.
  • #13 16390722
    _Megamax_
    Help: 29
    Rate: 131
    As colleagues write, the right wheel probably does not brake practically.
    To check the yokes of the springs and their front bushings, possibly the wishbone bushings, if it's a "hovercraft"
  • Replacing trailer brake control valve fixed uneven front braking
    #14 16420368
    wit-trans
    Rate: 68
    It turned out that the EBS 01056 error was periodically lit, which theoretically has nothing to do with the front axle - because it is an error of the trailer's control valve, but apparently it had an impact, because in the end this error turned on permanently and ended up replacing the valve controlling the brakes of the trailer, the error went out and the tractor's front axle started braking normally.
The discussion revolves around a braking issue with a MAN TGX 18.440 (2008) equipped with an EBS5 system, where the vehicle pulls strongly to the left during braking. The user has confirmed that the brake discs, pads, and calipers are in good condition, and no system errors are present. Suggestions include checking the right actuator for proper function, as a malfunction could lead to uneven braking. Other potential causes discussed include the geometry of the braking system, wheel bearings, and the ABS system. Ultimately, it was discovered that an EBS error related to the trailer's control valve was affecting the braking performance, which was resolved by replacing the valve, restoring normal braking on the front axle.
